WiFi setup
- Overview
- Setup Hardware
- Power up VOXL
- Configure Station Mode
- Configure SoftAP Mode
- Check VOXL’s IP Address
- Check WiFi Mode
VOXL supports two wifi modes, Station and SoftAP. Station Mode refers to the VOXL being configured into a typical ‘WiFi client’ on a wireless network like your phone or laptop. Software enabled Access Point Mode (SoftAP) configures VOXL to generate its own hotspot so that other WiFi devices can connect to it. This is useful if you are in the field away from your home or office WiFi network.
By default, the unit ships configured in SoftAP mode with an SSID of VOXL-XX:XX:XX:XX:XX:XX
with password 1234567890
(where XX:XX:XX:XX:XX:XX is the unit’s MAC address).
These instructions require the voxl-utils
package which is included in the base system image starting with v2.3.0 and was installed on your VOXL at the factory prior to that.
To continue to the next step in the quickstart sequence, you will need to configure VOXL’s WiFi in station mode and connect to a network with an internet connection so you can upgrade software packages. After that, you may refer to this page again to reconfigure WiFi in SoftAP mode or to connect to a new network.
Setup Hardware
- Disconnect power from the VOXL
- Attach Wi-Fi antennas as shown below (note it takes a little force to connect the MHF4 U.FL connectors)
Power up VOXL
To configure the VOXL into Station Mode, run the following command:
me@mylaptop:~$ adb shell voxl-wifi station <SSID> <Password>
A reboot of VOXL is required to finish the setup:
me@mylaptop:~$ adb reboot && adb wait-for-device
To configure the VOXL into Access Point Mode with your desired SSID, use the voxl-wifi
utility and reboot for the changes to take effect.
me@mylaptop:~$ adb shell voxl-wifi softap <SSID>
The password to connect to the VOXL’s hotspot is 1234567890
and VOXL will assign itself the IP 192.168.8.1
. Your device will be assigned an IP with DHCP in the 192.168.8.X subnet, usually 192.168.8.60, but not always.
VOXL will connect to the network when it powers up. If you need to locate its IP address, you can connct via ADB and run the following command:
me@mylaptop:~$ adb shell ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:81 errors:0 dropped:0 overruns:0 frame:0
TX packets:81 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:6140 (5.9 KiB) TX bytes:6140 (5.9 KiB)
wlan0 Link encap:Ethernet HWaddr 48:5F:99:9D:40:9D
inet addr:192.168.8.1 Bcast:192.168.8.255 Mask:255.255.255.0
inet6 addr: fe80::4a5f:99ff:fe9d:409d/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:218 errors:0 dropped:0 overruns:0 frame:0
TX packets:141 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3000
RX bytes:23365 (22.8 KiB) TX bytes:13134 (12.8 KiB)
Here you can see the localhost interface at 127.0.0.1 just as you have on your Linux host computer. The wlan0 interface is for the onboard WiFi.
Note: It’s not currently possible to assign a static IP, only DHCP is supported. If you need a static IP on your own wifi network it’s best to configure that in your router’s software.
Check WiFi Mode
Print the current mode (softap or station)
me@mylaptop:~$ voxl-wifi getmode
station
Configure hostname for Soft AP Mode (Optional)
It may be desired to have a dedicated hostname for your target instead of using an IP. This thread describes how to enable.
