Sentinel Reference Drone Quickstart
  1. Overview
  2. Overview
    1. What’s in the Box
    2. Required Materials
  3. Sentinel Vehicle Components
    1. Overview
      1. Front
      2. Side
      3. Top
      4. Bottom
  4. Sentinel Power Supply and Battery
    1. Safety First!
    2. Battery Information
  5. Benchtop Power Supply
The User’s Guide walks through taking Sentinel out of the box and up into the air!
What’s in the Box
sentinel-drone-only
  • Sentinel Drone
  • 10” props
  • Two sets of Propellor ring adapters
  • 5G Modem or Microhard Modem or Wifi (Optional)
sentinel-connectivity-options
Required Materials
To follow this user guide, you’ll need the following:
  • Spektrum Transmitter
    • e.g. SPMR6655, SPM8000 or SPMR8000
    • Any Spektrum transmitter with DSMX/DSM2 compatibility will likely work
    • Buy Here
  • Power Supply or Battery with XT60 connector
    • e.g. Gens Ace 5000mAh, or any 3S battery with XT60 connector
    • Buy Battery Here
    • Buy Power Supply Here
  • Host computer with:
    • QGroundControl 3.5.6+
    • Ubuntu 18.04+
    • Wi-Fi
  • USB Type C Cable
The following images give an overview of the vehicle components.
Front
View in fullsize Sentinel-Labeled-1
Side
View in fullsize Sentinel-Labeled-2
Top
View in fullsize Sentinel-Labeled-3
Bottom
View in fullsize Sentinel-Labeled-4
Next Step: Power and Battery
Safety First!
For setup and configuration of your Sentinel you must Remove the Propellers for safety.
Battery Information
Sentinel requires a Gens Ace 5000mAh, or any 3S battery with XT60 connector.
Buy Battery Here
vehicle-battery-connected
To install a 3s battery, slide into the body as shown. There is a stop at the front of the vehicle that will prevent the battery from sliding too far forward. The battery should be pressed all the way in until it hits the stop for a consistent center of mass.
Power on Sentinel by connecting the battery to the XT60 connector.
For desktop use, a 12VDC wall power supply can be used and is available here. This is convenient when doing development.
