Flight Core Configuration
  1. QGroundControl
  2. PX4 Parameter Files
  3. System Defaults
    1. Safety Switch Disabled
    2. MAVLink Instance 1
QGroundControl
Configuration of the VOXL Flight is fully supported by QGroundControl 4.0.
PX4 Parameter Files
Parameter files are available for reference:
System Defaults
The following describe the system defaults, as specified by boards/modalai/fc-v1/init/rc.board_defaults
The saftety switch can be ‘pressed’ by pulling J13 pin 5 up to 3.3V (which is provided by J13 pin 1). By default, we have the safety switch disabled, but it can be enabled via QGroundControl by setting CBRK_IO_SAFETY to 0.
  • configured by default at TELEM2 (exposed at J1) at 921600 baud in Normal mode
  • this is intended as the primary serial interface to communicate with VOXL
  • this is configurable by the user, except on VOXL Flight, since it’s in the PCB
Next: Flight Core Kits
