Setup ROS on VOXL 2
ModalAI Top Tip: ROS is not required to use or develop with VOXL 2.
Tutorial Video
Install ROS
VOXL 2 / RB5 Flight can use apt package management, which allows flexibility on what ROS version to install, and allows us to keep the core system image smaller. For these reasons, we leave it up to the end user to select what to install.
To install ROS Melodic (as an example), connect VOXL 2 / RB5 Flight to the internet and run the following:
apt-get update
apt install -y ros-melodic-ros-base ros-melodic-image-transport
MPA
If you have not already configured MPA, please check this out first as it is a pre-requisite.
As a shortcut, if you have a VOXL 2 Sentinel:
voxl-configure-mpa -p -f sentinel
If you have an RB5 Flight:
voxl-configure-mpa -p -f rb5-flight
Launch
Source ROS setup script:
voxl2:~$ . /opt/ros/melodic/setup.sh
Run the voxl_mpa_to_ros node, which uses this launch file /opt/ros/melodic/share/voxl_mpa_to_ros/launch/voxl_mpa_to_ros.launch
voxl2:~$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
You should get similar output:
... logging to /home/root/.ros/log/81ccbc5c-34ac-11ed-80c6-00c0caafca29/roslaunch-m0054-2535.log
Press Ctrl-C to interrupt
started roslaunch server http://m0054:45955/
SUMMARY
PARAMETERS
 * /rosdistro: melodic
 * /rosversion: 1.14.13
NODES
auto-starting new master
process[master]: started with pid [2557]
setting /run_id to 81ccbc5c-34ac-11ed-80c6-00c0caafca29
process[rosout-1]: started with pid [2568]
process[voxl_mpa_to_ros_node-2]: started with pid [2571]
MPA to ROS app is now running
Found new interface: hires
Found new interface: stereo_front
Found new interface: stereo_rear
Found new interface: tracking
Found new interface: imu_apps
Found new interface: voa_pc_out
List Topics
In a new shell, run the following:
voxl2:~$ rostopic list
/hires
/imu_apps
/qvio/odometry
/qvio/pose
/qvio_overlay
/rosout
/rosout_agg
/stereo_front/left
/stereo_front/right
/stereo_rear/left
/stereo_rear/right
/tracking
/voa_pc_out
Next Steps
See the MAVROS test example for VOXL 2.
