VOXL 2 Offboard Sensors
  1. VOXL2 IO / RC Input
  2. GPS (GNSS/Mag)
  3. Power Monitoring
  4. External SPIs
VOXL2 IO / RC Input
VOXL 2 IO provides the ability to extend VOXL 2 with PWM outputs and additional supported RC inputs and can connect here.
m0054-offboard-sensors-rc
J19: Full pinouts for all the connects are available here.
Pin #Signal NameNotes
1 Not used for RC
2 Not used for RC
3 Not used for RC
4 Not used for RC
5 Not used for RC
6 Not used for RC
7 Not used for RC
8 Not used for RC
9VREG_3P3V_RCRC power *, controllable via GPIO 159
10RCIO_UART_TX (Output)SSC_QUP7, 3.3V signal levels
11RCIO_UART_RX (Input)SSC_QUP7, 3.3V signal levels
12GND
GPS (GNSS/Mag)
An external GPS (GNSS/Mag) can be connected to VOXL 2’s J19 connector.
m0054-offboard-sensors-gnss-mag
Name / DesignatorDescriptionInterface
GNSS UART / exposed via J19PX4 GNSSSSC_QUP6, 2W UART, SLPI (sDSP)
Mag I2C / exposed via J19PX4 MagSSC_QUP0, I2C, SLPI (sDSP)
1VDC_5V_LOCALGNSS/Mag power *
2GNSS TX 3P3Vslpi_proc, SSC_QUP7
3GNSS RX 3P3Vslpi_proc, SSC_QUP7
4MAG SCL 3P3Vslpi_proc, SSC_QUP1
5MAG SDA 3P3Vslpi_proc, SSC_QUP1
6GND
7 Not used for GNSS/Mag
8 Not used for GNSS/Mag
9 Not used for GNSS/Mag
10 Not used for GNSS/Mag
11 Not used for GNSS/Mag
12 Not used for GNSS/Mag
Power Monitoring
m0054-offboard-sensors-pm
Although not technically onboard VOXL 2, using the VOXL Power Module v3 provides the ability to monitor battery voltage and regulated 5VDC voltage from the power module.
Name / DesignatorDescriptionInterfaceDriver
PX4 Power Monitoring (J4)QTY2 INA231SSC_QUP2, I2C, SLPI (sDSP), Addrs: 0x44h and 0x45hvoxlpm
J4: Full pinouts for all the connects are available here.
Pin#SignalNotes/Usage
1VDCIN_5VDC from Power Module, “unprotected”
2GNDPower Module Return
3I2C_CLKSSC_QUP_1, 5V signal levels, Pullups on Power Module
4I2C_SDASSC_QUP_1, 5V signal levels, Pullups on Power Module
External SPIs
The following SPI busses are available from the applications processor.
m0054-offboard-sensors-spi
SPI0 / exposed via J6camera group 0 SPI/dev/spidev0.0
SPI1 / exposed via J7camera group 1 SPI/dev/spidev1.0
SPI14 / exposed via J10external SPI/dev/spidev14.0
Related video:
