FLIR Lepton
  1. Overview
  2. Connecting
  3. Set up voxl-flir-server
  4. Source
voxl-flir-server is an application to send video frames from the FLIR Lepton SPI camera to MPA pipes.
For Flir UVC enabled cameras with USB interfaces such as the Boson 640 and PureThermal Mini Pro with Lepton use voxl-uvc-server instead.
Connecting
On VOXL1, the FLIR Lepton should be connected to SPI bus 9. On VOXL2, the FLIR Lepton should be connected to SPI bus 14.
TODO make a wiring diagram.
voxl-flir-server was introduced in VOXL SDK 0.9, and is available in the voxl package repos but is not installed by default.
To install on VOXL2:
apt update
apt install voxl-flir-server
To install on VOXL1
opkg update
opkg install voxl-flir-server
On both platforms, you can run the voxl-flir-server binary manually from the command line for debugging and testing, or enable the systemd background service to start it automatically on boot:
systemctl enable voxl-flir-server
systemctl start voxl-flir-server
Source
Source code is here.
