VOXL 2 QUPs
Together, the Qualcomm Universal Peripheral v3 and the TrustZone provide access to various protocols on various hardware interfaces. Trustzone is a necessary component that requires updates to in order to change protocol/interfaces.
Trusztone images are flashed during the system image installation (devcfg.mbn). The toolchain and source code to build the Trustzone image are unfortunately not open source.
devcfg
VOXL 2 - M0054
| QUP | Protocol | QRB5165 GPIO | Notes | Connector/Routing | Device | Notes |
| QUP0 0x980000 | SPI | 28-31 | Camera Group 0 SPI | J6 - 34,36,38,40, apps proc | /dev/spidev0.0 | sys image 1.3+ |
| QUP1 0x984000 | I2C | 4-5 | Camera Group 1 I2C | J7 - 34,36, apps proc | /dev/i2c-4 | sys image 1.5+ |
| QUP2 0x988000 | I2C | 115-116 | HS B2B I2C2 | J5 - 8,9 | /dev/i2c-0 | |
| QUP3 0x98c000 | SPI | 119-122 | Onboard IMU1, 42688p, | U7, apps proc | /dev/spidev3.0 | sys image 1.3+ |
| QUP4 | NA | |||||
| QUP5 0x994000 | UART | 12-15 | Camera Group 2 UART | J8 - 34,36,38,40 | /dev/ttyHS0 | sys image 1.4+ |
| QUP6 | HS UART | |||||
| QUP7 0x99c000 | HS UART | 22-23 | B2B 2W UART | J3 - 3,5 | /dev/ttyHS1 | sys image 1.3+ |
| QUP8 | NA | |||||
| QUP9 0xa84000 | I2C | 125-126 | B2B I2C9 | J3 - 13,15 | /dev/i2c-1 | sys image 1.3+ |
| QUP10 0xa88000 | I2C | 129-130 | B2B I2C10 | J3 - 23,25 | /dev/i2c-2 | sys image 1.3+ |
| QUP11 0xa8c000 | SPI | 60-63 | HS B2B SPI | J5 - 53,56 | /dev/spidev11.0 | sys image 1.5+ |
| QUP12 0xa90000 | debug | 34-35 | Debug Console (2W UART, 115200 baud) | J3 - 27,29 | Not in perf build | sys image 1.3+ |
| QUP13 0xa94000 | UART | HS B2B UART | J5 - 95,98 | sys image 1.5+ | ||
| QUP14 0x880000 | SPI | 40-43 | External SPI J10 | J10, apps proc, | /dev/spidev14.0 | sys image 1.3+ |
| QUP15 0x884000 | I2C | 44-45 | (internal use) | /dev/i2c-3 | ||
| QUP16 | NA | |||||
| QUP17 | NA | |||||
| QUP18 | NA | |||||
| QUP19 0x894000 | HS UART | 2-3 | HS B2B 2W UART | J5 - 48,49 | /dev/ttyHS2 | sys image 1.3+ |
Version 8
- used in system image 1.5+
- convert qup1 from SPI to I2C to expose apps_proc I2C on camera group
Version 7
- enable qup2: I2C, for HS B2B J5 pins 8/9, support for M0130 add-on I2C on J8
- enable qup11: SPI, for HS B2B J5 pins 53/56, support for M0130 add-on SPI on J8
- enable qup13: UART, for HS B2B J5 pins 36-39
- version 7, M0054-VOXL2(md5sum: 77366973052c03ce3eab57c1e92b490a)
Version 6
- used in system image 1.3+
- enable qup7: 2W UART, for B2B J3 pins 3/5, support for M0125 add-on UART
- version 6, M0054-VOXL2(md5sum: 3698389194c899953c4e337a7b48cb97)
RB5 Flight M0052
Download:
- M0052-RB5-FLIGHT- (md5sum: cf613de37db6e7d2bb245f4d17cab79e)
Deltas from M0054 version 6 above:
| QUP5 0x994000 | UART | 12-15 | Camera Group 2 UART | J8 - 34,36,38,40 | /dev/ttyHS3 |
| QUP6 0x998000 | HS UART | SOM WiFi | internal | /dev/ttyHS0 | |
| QUP7 0x99c000 | HS UART | 22-23 | B2B 2W UART | J3 - 3,5 | /dev/ttyHS4 |
| QUP13 0xa94000 | UART | 38-39 | PX4 RC input | apps_proc, M0052-J12 | /dev/ttyHS1 |
| QUP18 0x890000 | UART | 58-59 | PX4 GNSS | apps_proc, M0052-J10 | /dev/ttyHS2 |
| QUP19 0x894000 | HS UART | 2-3 | HS B2B 2W UART | J5 - 48,49 | /dev/ttyHS5 |
