VOXL 2 QDL Guide
What is it?
QDL is a Qualcomm tool that can be used to program (or unbrick) Snapdragon based devices.
How does it work?
Snapdragon based devices contain a special mode of operation, called Emergency Download Mode (EDL). In this mode, the device identifies itself as 05c6:901d Qualcomm, Inc.
via. USB and can communicate with a PC host.
EDL mode itself implements the Qualcomm Sahara protocol, which accepts an OEM-digitally-signed programmer over USB. The programmer implements the Firehose protocol which allows the host PC to send commands to write into the onboard storage (UFS).
An open source tool (for Linux) that implements the Qualcomm Sahara and Firehose protocols has been developed by Linaro, and can be used to program (or unbrick) Snapdragon based devices.
Usage
Prerequisites
Ubuntu Host
A couple different libraries are required to build the QDL program, install them using the following:
sudo apt-get install libxml2-dev libudev-dev
Some Linux distributions come with ModemManager
, a tool for configuring Mobile Broadband. This program, if installed, will interfere with the QDL flashing. Remove the program with the following:
sudo apt remove --purge modemmanager
If you need ModemManager, you can simply stop it from running with
sudo systemctl stop ModemManager
and restart it with:
sudo systemctl start ModemManager
OSX Host
Install libusb
brew install libusb
brew link libusb
Build
Clone the QDL repository using the following:
git clone https://git.linaro.org/landing-teams/working/qualcomm/qdl.git
Move into the project directory:
cd qdl
Build / install program using:
# build
make
# install
make install
This will install the qdl
program into /usr/local/bin
Test the install by running the following and verifying the output:
qdl
qdl [--debug] [--storage <emmc|nand|ufs>] [--finalize-provisioning] [--include <PATH>] <prog.mbn> [<program> <patch> ...]
Image Download
Download the latest image release from the ModalAI protected downloads page
Latest: VOXL2 QDL Image 14.1a_1.1.2
Unzip the downloaded release:
unzip r14.1a_1.1.2-M0054-14.1a-FLAT-V3.zip
Move into the ufs
sub-directory of the unzipped release:
cd 1.1.2-M0054-14.1a-FLAT-V3/ufs
Flash
Hardware preparation
In order to force your VOXL2 into EDL mode, slide the SW2
switch into the ON
position, see below:
Now plug in power and USB-C cable from VOXL2 to host PC.
Initiate flash
While in the ufs
sub-directory of the image release, run the following qdl
command in order to flash the device:
sudo qdl --debug --storage ufs --include . prog_firehose_ddr.elf rawprogram_unsparse0.xml rawprogram1.xml rawprogram2.xml rawprogram3.xml rawprogram4.xml rawprogram5.xml patch0.xml patch1.xml patch2.xml patch3.xml patch4.xml patch5.xml
All of the required *.xml
files as well as the directory path (in this case we use .
to represent the current directory location) need to be specified in order for qdl
to find all of the required flash data.
The qdl
flash will take 10-15 minutes to complete (may be faster or slower depending on hardware and USB cable).
Once completed, you should see an output similar to the following:
<response value="ACK" rawmode="false" /></data>
partition 1 is now bootable
<data><power value="reset"/></data>
<data>
<log value="INFO: Calling handler for power" /></data>
LOG: INFO: Calling handler for power
<data>
Remove power and USB from the VOXL2, slide SW2
switch back to the OFF
position.
You can now plug in power and USB and after a short time (first boot after QDL takes slightly longer than following boots) ADB will be available.
Verify that the flash was successful by checking the installed image version:
# adb onto VOXL2
adb shell
# check version
root@qrb5165-rb5:/# cat /etc/version
This version should match the image you just flashed.
DEBUGGING NOTE: If you are unable to ADB onto the device but the device is being detected correctly by the host PC as seen below:
lsusb
Bus 001 Device 022: ID 05c6:901d Qualcomm, Inc. KONA-QRD _SN:21217FEB
restarting the ADB server may fix the issue:
adb kill-server
adb start-server
You should now be able to ADB onto your device successfully.
Next Steps
Now that your VOXL2 has been reset to the factory image, install the latest System Image release by following the instructions here: VOXL2 System Image
