VOXL 2 Connectors
- Video Overview of Connectors
- Connector Callouts
- Buttons
- Pinouts
Connector Callouts
All single ended signals on B2B connectors J3, J5, J6, J7, and J8 are 1.8V CMOS unless explicitly noted. All single ended signals on cable-to-board connectors J10, J18, & J19 are 3.3V CMOS unless explicitly noted.
| Connector | Description | MPN (Board Side) | Mating MPN (Board/Cable Side) | Type | Signal Feature Summary |
| J2 | Fan | SM02B-SRSS-TB(LF)(SN) | SHR-02V-S | Cable Header, 2-pin R/A | 5V DC for FAN + PWM Controlled FAN-Return (GND) |
| J3 | Legacy B2B | QSH-030-01-L-D-K-TR | QTH-030-01-L-D-A-K-TR | B2B Receptacle, 60-pin | 5V/3.8V/3.3V/1.8V power for plug-in boards, JTAG and Debug Signals, QUP expansion, GPIOs, USB3.1 Gen 2 (USB1) |
| J4 | Prime Power In | 22057045 | 0050375043 | Cable Connector, 4-pin R/A | +5V main DC power in + GND, I2C@5V for power monitors |
| J5 | High Speed B2B | ADF6-30-03.5-L-4-2-A-TR | ADM6-30-01.5-L-4-2-A-TR | B2B Socket, 120-pin | More 3.8V/3.3V/1.8V power for plug-in boards, 5V power in for “SOM Mode”, QUP expansion, GPIOS (including I2S), SDCC (SD Card V3.0), UFS1 (secondary UFS Flash), 2L PCIe Gen 3, AMUX and SPMI PMIC signals |
| J6 | Camera Group 0 | DF40C-60DP-0.4V(51) | DF40C-60DS-0.4V | B2B Plug, 60-pin | Qty-2 4L MIPI CSI ports, CCI and camera control signals, 8 power rails (from 1.05V up to 5V) for cameras and other sensors, dedicated SPI (QUP) port |
| J7 | Camera Group 1 | DF40C-60DP-0.4V(51) | DF40C-60DS-0.4V | B2B Plug, 60-pin | Qty-2 4L MIPI CSI ports, CCI and camera control signals, 8 power rails (from 1.05V up to 5V) for cameras and other sensors, dedicated SPI (QUP) port |
| J8 | Camera Group 2 | DF40C-60DP-0.4V(51) | DF40C-60DS-0.4V | B2B Plug, 60-pin | Qty-2 4L MIPI CSI ports, CCI and camera control signals, 8 power rails (from 1.05V up to 5V) for cameras and other sensors, dedicated SPI (QUP) port |
| J9 | USB-C (ADB) | UJ31-CH-3-SMT-TR | USB Type-C | Cable Receptacle, 24-pin R/A | ADB USB-C with re-driver and display port alternate mode (USB0) |
| J10 | SPI Expansion | SM08B-GHS-TB(LF)(SN) | GHR-08V-S | Cable Header, 8-pin R/A | SPI@3.3V with 2 CS_N pins, 32kHz CLK_OUT@3.3V |
| J18 | ESC (SLPI Access) | SM04B-GHS-TB(LF)(SN) | GHR-04V-S | Cable Header, 4-pin R/A | ESC UART@3.3V, 3.3V reference voltage |
| J19 | GNSS/MAG/RC/I2C (SLPI Access) | SM12B-GHS-TB(LF)(SN) | GHR-12V-S | Cable Header, 12-pin R/A | GNSS UART@3.3V, Magnetometer I2C@3.3V, 5V, RC UART, Spare I2C |
Add-on Board to Board Design Package
Reference add-on board Altium schematic package can be downloaded here
Buttons
SW1 - Force Fastboot Button
Force Fastboot momentary button.
To force device into fastboot mode:
- power off device, remove USB cable to completely power down
- press and hold SW1 button down
- power on device, attach USB cable
- release SW1 button
- from host computer, run
fastboot devicesand verify the device shows up. If not, restart this procedure
To reboot device to fastboot:
- device is powered on
- press and hold SW1 for 30 seconds until the device reboots into fastboot mode
SW2 - EDL Switch
Emergency Download switch, used for factory flashing. Should be left OFF. See user guide for QDL if interested in more information.
Pinouts
J2 - 5VDC Fan Control
| Pin # | Signal Name | Notes |
| 1 | VDC_5V_LOCAL | 5V protected power output * |
| 2 | FAN RETURN (GND) | Return limited to ~400mA |
J3 - Legacy Board to Board Connector (B2B)
Currently Supported Legacy Add-Ons:
- M0017 USB Debug Add-On
- M0030 LTE Modem Add-On
- M0048 Microhard Modem Add-On
The Legacy Board to Board connector is designed to host VOXL Add-ons such as the LTE Add-on v2 and the Microhard Add-on.
| Connector | MPN |
| Board Connector | QSH-030-01-L-D-K-TR |
| Mating Connector | QTH-030-01-L-D-A-K-TR |
J3 Pin-out
| Odd Pin # | Signal/Voltage | Even Pin # | Signal/Voltage |
| 1 | DGND | 2 | VDC_5V_LOCAL |
| 3 | GPIO_23_UART7_RXD, /dev/ttyHS1 | 4 | VDC_5V_LOCAL |
| 5 | GPIO_22_UART7_TXD, /dev/ttyHS1 | 6 | VDC_5V_LOCAL |
| 7 | GPIO_52_SPI17_MISO | 8 | USB1_HS_ID_LEGACY (Normally N.C.) |
| 9 | GPIO_53_SPI17_MOSI | 10 | DGND |
| 11 | DGND | 12 | USB1_HS_DM |
| 13 | GPIO_126_I2C9_SCL | 14 | USB1_HS_DP |
| 15 | GPIO_125_I2C9_SDA | 16 | VDC_5V_LOCAL_USB1 |
| 17 | GPIO_55_SPI17_CS | 18 | DGND |
| 19 | GPIO_54_SPI17_SCLK | 20 | USB1_SS_TX_M |
| 21 | DGND | 22 | USB1_SS_TX_P |
| 23 | GPIO_130_I2C10_SCL, /dev/i2c-1 | 24 | GPIO_20 |
| 25 | GPIO_129_I2C10_SDA, /dev/i2c-1 | 26 | GPIO_21 |
| 27 | GPIO_35_DBG_UART12_RX | 28 | GPIO_32_QUP12_L0 |
| 29 | GPIO_34_DBG_UART12_TX | 30 | GPIO_33_QUP12_L1 |
| 31 | DGND | 32 | USB1_SS_RX_M |
| 33 | JTAG_SRST_N | 34 | USB1_SS_RX_P |
| 35 | JTAG_TCK | 36 | DGND |
| 37 | JTAG_TDI | 38 | GPIO_131_USB_HUB_RESET |
| 39 | JTAG_TDO | 40 | GPIO_124 |
| 41 | JTAG_TMS | 42 | GPIO_145 |
| 43 | JTAG_TRST_N | 44 | DGND |
| 45 | JTAG_PS_HOLD | 46 | GPIO_90_FAST_BOOT_3 |
| 47 | VREG_S4A_1P8 | 48 | GPIO_76_FAST_BOOT_2 |
| 49 | PM_RESIN_N | 50 | GPIO_47_SPI14_CS2_FAST_BOOT_1 |
| 51 | SDM_RESOUT_N | 52 | GPIO_27_FAST_BOOT_0 |
| 53 | VREG_3P3V_LOCAL | 54 | GPIO_128_WDOG_DIS |
| 55 | KPD_PWR_N | 56 | SDM_FORCE_USB_BOOT |
| 57 | VPH_PWR | 58 | DGND |
| 59 | DGND | 60 | CLK_PMK_PMIC |
J4 - Power Connector / I2C Battery Monitoring
For use with VOXL Power Module
| 1 | VDCIN_5V | DC from Power Module, “unprotected” |
| 2 | GND | Power Module Return |
| 3 | I2C_CLK | SSC_QUP_1, 5V signal levels, Pullups on Power Module |
| 4 | I2C_SDA | SSC_QUP_1, 5V signal levels, Pullups on Power Module |
Input Power Requirements
The VOXL Power Module provides the needed voltage and current demands of both VOXL (5V), VOXL 2 (5V), and VOXL 2 Mini (3.8V). It is a well tested and proven design.
For VOXL 2, we5V +/- 5% is expected to keep the eFuse happy. The VOXL Power Module is set for 5.08V at no-load to help compensate for any cable drops. 6A of in-rush support is required during power-on. The steady-state current requirement depends on your application and if a plug-in board (5G modem, Microhard, etc) is connected.
If you design with a 3A DC/DC, you will likely not be able to boot the system due to power on in-rush. Please use a 6A device for success with at least 188uF of bulk capacitance (qty-4 47uF for example) to match the VOXL Power Module performance.
If one needs to design their own power module, please submit a PCB review on our forum here
J5 - High Speed Board to Board Connector (HSB2B)
Currently Supported Add-Ons:
- M0062 - Debug/PCIe Add-On
- M0067 - 5G Add-On
- M0090 - 5G Add-On
| Connector | MPN |
| Board Connector | ADF6-30-03.5-L-4-2-A-TR |
| Mating Connector | ADM6-30-01.5-L-4-2-A-TR |
J5 Pin-out
| Pin | Signal/Voltage | Pin | Signal/Voltage | Pin | Signal/Voltage | Pin | Signal/Voltage |
| A1 (1) | VDCIN_5V | B1 (31) | VDCIN_5V | C1 (61) | VDCIN_5V | D1 (91) | VDCIN_5V |
| A2 | VDCIN_5V | B2 | VDCIN_5V | C2 | VDCIN_5V | D2 | VDCIN_5V |
| A3 | GND | B3 | GND | C3 | GND | D3 | GND |
| A4 | GND | B4 | GND | C4 | GND | D4 | GND |
| A5 | VREG_3P3V_LOCAL | B5 | GND | C5 | GPIO_119_SPI3_MISO | D5 | GPIO_36_UART13_CTS |
| A6 | VREG_3P3V_LOCAL | B6 | GND | C6 | GPIO_120_SPI3_MOSI | D6 | GPIO_37_UART13_RTS |
| A7 | GND | B7 | GPIO_16_QUP6_L0 | C7 | GPIO_121_SPI3_SCLK | D7 | GPIO_38_UART13_TXD |
| A8 | GPIO_115_I2C2_SDA | B8 | GPIO_17_QUP6_L1 | C8 | GPIO_122_SPI3_CS | D8 | GPIO_39_UART13_RXD |
| A9 | GPIO_116_I2C2_SCL | B9 | GPIO_18_QUP6_L2 | C9 | GPIO_24_I2C8_SDA | D9 | GPIO_8_I2C4_SDA |
| A10 | GPIO_117_QUP2_L2 | B10 | GPIO_19_QUP6_L3 | C10 | GPIO_25_I2C8_SCL | D10 | GPIO_9_I2C4_SCL |
| A11 | GPIO_118_QUP2_L3 | B11 | GPIO_155 | C11 | GND | D11 | PM8250_AMUX1 |
| A12 | SD_UFS_CARD_DET_N | B12 | GPIO_154 | C12 | GPIO_145 (intentional duplicate to Legacy B2B pin 42) | D12 | GND |
| A13 | GND | B13 | GPIO_153 | C13 | GPIO_144 | D13 | PCIE2_REFCLK_M |
| A14 | SDC2_CLK | B14 | GPIO_152 | C14 | GPIO_143 | D14 | PCIE2_REFCLK_P |
| A15 | GND | B15 | GND | C15 | GPIO_142 | D15 | GND |
| A16 | VREG_L9C_2P96 | B16 | GPIO_0_QUP19_L0 | C16 | GPIO_137 | D16 | PCIE2_RX0_M |
| A17 | SDC2_CMD | B17 | GPIO_1_QUP19_L1 | C17 | GND | D17 | PCIE2_RX0_P |
| A18 | SDC2_DATA_0 | B18 | GPIO_2_QUP19_L2, /dev/ttyHS2 | C18 | GPIO_88 | D18 | GND |
| A19 | SDC2_DATA_1 | B19 | GPIO_3_QUP19_L3, /dev/ttyHS2 | C19 | GPIO_89 | D19 | PCIE2_RX1_M |
| A20 | SDC2_DATA_2 | B20 | GPIO_56_I2C18_SDA | C20 | GPIO_87_PCIE2_WAKE_N | D20 | PCIE2_RX1_P |
| A21 | SDC2_DATA_3 | B21 | GPIO_57_I2C18_SCL | C21 | GPIO_86 | D21 | GND |
| A22 | GND | B22 | GND | C22 | GPIO_85 | D22 | PCIE2_TX0_M |
| A23 | UFS1_REFCLK | B23 | GPIO_60_QUP11_L0 | C23 | GND | D23 | PCIE2_TX0_P |
| A24 | GND | B24 | GPIO_61_QUP11_L1 | C24 | PMIC_8150L_AMUX1 | D24 | GND |
| A25 | UFS1_TX0_M | B25 | GPIO_62_QUP11_L2 | C25 | GND | D25 | PCIE2_TX1_M |
| A26 | UFS1_TX0_P | B26 | GPIO_63_QUP11_L3 | C26 | GND | D26 | PCIE2_TX1_P |
| A27 | GND | B27 | GND | C27 | GND | D27 | GND |
| A28 | UFS1_RX0_M | B28 | SPMI_CLK | C28 | VPH_PWR_3P8V | D28 | GND |
| A29 | UFS1_RX0_P | B29 | SPMI_DATA | C29 | VPH_PWR_3P8V | D29 | VREG_S4A_1P8 |
| A30 (30) | GND | B30 (60) | GND | C30 (90) | VPH_PWR_3P8V | D30 (120) | VREG_S4A_1P8 |
Camera Group J6, J7, and J8 Pin-outs
General Pin-out
Generic camera group pinout, please work with ModalAI for any mating designs to gauranteee proper operation
| Pin# | Signal |
| 1 | GND |
| 2 | GND |
| 3 | Lower CCI_I2C_SDA |
| 4 | DVDD 1.2V |
| 5 | Lower CCI_I2C_SCL |
| 6 | DOVDD 1.8V |
| 7 | GND |
| 8 | DVDD 1.05V |
| 9 | Lower CSI_CLK_P |
| 10 | Lower RST_N |
| 11 | Lower CSI_CLK_M |
| 12 | Lower MCLK |
| 13 | Lower CSI_DAT0_P |
| 14 | GND |
| 15 | Lower CSI_DAT0_M |
| 16 | Lower CCI Timer |
| 17 | GND |
| 18 | Upper CCI Timer |
| 19 | Lower CSI_DATA1_P |
| 20 | Upper MCLK |
| 21 | Lower CSI_DATA1_M |
| 22 | AVDD 2.8V |
| 23 | Lower CSI_DATA2_P |
| 24 | GND |
| 25 | Lower CSI_DATA2_M |
| 26 | Upper RST_N, Shared |
| 27 | GND |
| 28 | Upper CCI_I2C_SDA |
| 29 | Lower CSI_DATA3_P |
| 30 | Upper CCI_I2C_SCL |
| 31 | Lower CSI_DATA3_M |
| 32 | Spare MCLK/GPIO |
| 33 | GND |
| 34 | Group SPI MISO (groups 0/1) |
| 35 | Upper CSI_CLK_P |
| 36 | Group SPI MOSI (groups 0/1) |
| 37 | Upper CSI_CLK_M |
| 38 | Group SPI SCLK (groups 0/1) |
| 39 | Upper CSI_DATA0_P |
| 40 | Group SPI CS_N (groups 0/1) |
| 41 | Upper CSI_DATA0_M |
| 42 | VREG_S4A_1P8 |
| 43 | GND |
| 44 | GND |
| 45 | Upper CSI_DATA1_P |
| 46 | VPH_PWR 3.8V |
| 47 | Upper CSI_DATA1_M |
| 48 | VPH_PWR 3.8V |
| 49 | Upper CSI_DATA2_P |
| 50 | GND |
| 51 | Upper CSI_DATA2_M |
| 52 | 3.3V |
| 53 | GND |
| 54 | GND |
| 55 | Upper CSI_DATA3_P |
| 56 | 5V |
| 57 | Upper CSI_DATA3_M |
| 58 | 5V |
| 59 | GND |
| 60 | GND |
J6 - Camera Group 0 Specific Pinout
Configured for the following hardware:
+--> M0010
- M0054 J6 <--> M0076-1 interposer <--> M0010 <--|
+--> M0010
More camera information here More regulator information here
Connector: DF40C-60DP-0.4V(51)
Device Tree:
qcom,cam-sensor0qcom,cam-sensor1
J6 Pin-out
| Pin # | Signal Name | Usage / Notes |
| 1 | GND | |
| 2 | GND | |
| 3 | CCI_I2C0_SDA | CAM0_CCI0_SDA, gpio101 |
| 4 | VREG_PM8009_L2_1P2 | DVDD 1.2V |
| 5 | CCI_I2C0_SCL | CAM0_CCI0_SCL, gpio102 |
| 6 | VREG_PM8009_L7_1P8 | CAM0_VIO_1P8, CAM0_VIO_1P8 |
| 7 | GND | |
| 8 | VREG_PM8009_L1_1P05 | CAM0_VDD_1P05, NOTE: current this is ~1.13VDC |
| 9 | CSI0_CLK_CON_P | |
| 10 | GPIO_93_CAM0_RST_N | CAM0_RST_N, gpio93 |
| 11 | CSI0_CLK_CON_N | |
| 12 | GPIO_94_CAM_MCLK0_CON | CAM_MCLK0_CON, gpio94 |
| 13 | CSI0_LANE0_CON_P | LEFT |
| 14 | GND | |
| 15 | CSI0_LANE0_CON_N | LEFT |
| 16 | GPIO_110_CCI_TIMER1 | (unused in version 0) |
| 17 | GND | |
| 18 | GPIO_113_CCI_TIMER4 | CAM_FSYNC_1_OUT, CAM_FSYNC0_IN |
| 19 | CSI0_LANE1_CON_P | RIGHT |
| 20 | CAM_MCLK1_CON | CAM_MCLK1_CON, gpio95 |
| 21 | CSI0_LANE1_CON_N | RIGHT |
| 22 | VREG_PM8009_L5_2P8 | CAM0_AVDD_2P8, CAM1_AVDD_2P8 |
| 23 | CSI0_LANE2_CON_P | |
| 24 | GND | |
| 25 | CSI0_LANE2_CON_N | |
| 26 | GPIO_109_CAM3_RST_N | (shared, CAM3_RST_N) |
| 27 | GND | |
| 28 | CCI_I2C1_SDA | CAM1_CCI1_SDA, CAM4_CCI1_SDA |
| 29 | CSI0_LANE3_CON_P | |
| 30 | CCI_I2C1_SCL | CAM1_CCI1_SCL, CAM4_CCI1_SCL |
| 31 | CSI0_LANE3_CON_N | |
| 32 | MCLK6_G0_CON | (shared) CAM1_RST_N, gpio100, |
| 33 | GND | |
| 34 | GPIO_28_CAM0_SPI0_MISO | /dev/spidev0.0 |
| 35 | CSI1_CLK_CON_P | |
| 36 | GPIO_29_CAM0_SPI0_MOSI | /dev/spidev0.0 |
| 37 | CSI1_CLK_CON_N | |
| 38 | GPIO_30_CAM0_SPI0_CLK | /dev/spidev0.0 |
| 39 | CSI1_LANE0_CON_P | |
| 40 | GPIO_31_CAM0_SPI0_CS | /dev/spidev0.0 |
| 41 | CSI1_LANE0_CON_N | |
| 42 | VREG_S4A_1P8 | |
| 43 | GND | |
| 44 | GND | |
| 45 | CSI1_LANE1_CON_P | |
| 46 | VPH_PWR | |
| 47 | CSI1_LANE1_CON_N | |
| 48 | VPH_PWR | |
| 49 | CSI1_LANE2_CON_P | |
| 50 | GND | |
| 51 | CSI1_LANE2_CON_N | |
| 52 | VREG_3P3V_LOCAL | |
| 53 | GND | |
| 54 | GND | |
| 55 | CSI1_LANE3_CON_P | |
| 56 | VDC_5V_LOCAL | |
| 57 | CSI1_LANE3_CON_N | |
| 58 | VDC_5V_LOCAL | |
| 59 | GND | |
| 60 | GND |
J7 - Camera Group 1 Specific Pinout
+--> M0014 (M0084-JL - lower)
- M0054 J7 <--> M0084 flex <----|
+--> M0025-2 (M0084-JU - upper)
Device Tree:
qcom,cam-sensor2qcom,cam-sensor3
J7 Pin-out
| 1 | GND | |
| 2 | GND | |
| 3 | CCI_I2C2_SDA | CAM2_CCI1_SDA, gpio105 |
| 4 | VREG_PM8009_L2_1P2 | (M0084, R1 not stuffed, not routed) |
| 5 | CCI_I2C2_SCL | CAM2_CCI1_SCL, gpio106 |
| 6 | VREG_PM8009_L7_1P8 | CAM2_DOVDD_1P8, CAM3_DOVDD_1P8 |
| 7 | GND | |
| 8 | VREG_PM8009_L1_1P05 | (M0084, R2 stuffed) CAM2_VDD_1P05,CAM3_VDD_1P05 (NOTE: current this is ~1.13VDC) |
| 9 | CSI2_CLK_CON_P | |
| 10 | GPIO_92_CAM1_RST_N | RST_LOWER_N, gpio92 |
| 11 | CSI2_CLK_CON_N | |
| 12 | GPIO_96_CAM_MCLK2 | MCLK_LOW, gpio96 |
| 13 | CSI2_LANE0_CON_P | |
| 14 | GND | |
| 15 | CSI2_LANE0_CON_N | |
| 16 | GPIO_111_CCI_TIMER2 | CCI_TIMER_LOWER |
| 17 | GND | |
| 18 | GPIO_114_CCI_ASYNC_IN | CCI_TIMER_UPPER |
| 19 | CSI2_LANE1_CON_P | |
| 20 | GPIO97_CAM_MCLK3_CON | MCLK_UPPER, gpio97 |
| 21 | CSI2_LANE1_CON_N | |
| 22 | VREG_PM8009_L6_2P8 | AVDD_2P8, CAM2_DOVDD_2P8, CAM3_DOVDD_2P8 |
| 23 | CSI2_LANE2_CON_P | |
| 24 | GND | |
| 25 | CSI2_LANE2_CON_N | |
| 26 | GPIO_109_CAM3_RST_N | (shared, RST_UPPER_SHARED_N) |
| 27 | GND | |
| 28 | CCI_I2C3_SDA | CAM3_CCI3_SDA, CAM5_CCI3_SDA, gpio107 |
| 29 | CSI2_LANE3_CON_P | |
| 30 | CCI_I2C3_SCL | CAM3_CCI3_SCL, CAM5_CCI3_SCL, gpio108 |
| 31 | CSI2_LANE3_CON_N | |
| 32 | MCLK6_G1_CON | (shared) GPIO_MCLK6_SHARED, gpio100 |
| 33 | GND | |
| 34 | GPIO_4_CAM1_SPI1_MISO | GPIO_4, /dev/spidev1.0 can be enabled in DT, see this commit to see how to re-enable if needed. |
| 35 | CSI3_CLK_CON_P | |
| 36 | GPIO_5_CAM1_SPI1_MOSI | GPIO_5, /dev/spidev1.0 can be enabled in DT see this commit to see how to re-enable if needed. |
| 37 | CSI3_CLK_CON_N | |
| 38 | GPIO_6_CAM1_SPI1_CLK | GPIO_6, /dev/spidev1.0 can be enabled in DT see this commit to see how to re-enable if needed. |
| 39 | CSI3_LANE0_CON_P | |
| 40 | GPIO_7_CAM1_SPI1_CS | GPIO_7, /dev/spidev1.0 can be enabled in DT see this commit to see how to re-enable if needed. |
| 41 | CSI3_LANE0_CON_N | |
| 43 | GND | |
| 44 | GND | |
| 45 | CSI3_LANE1_CON_P | |
| 46 | VPH_PWR | |
| 47 | CSI3_LANE1_CON_N | |
| 48 | VPH_PWR | |
| 49 | CSI3_LANE2_CON_P | |
| 50 | GND | |
| 51 | CSI3_LANE2_CON_N | |
| 53 | GND | |
| 54 | GND | |
| 55 | CSI3_LANE3_CON_P | |
| 57 | CSI3_LANE3_CON_N | |
| 59 | GND | |
| 60 | GND |
J8 - Camera Group 2 Specific Pinout
+--> M0010
- M0054 J8 <--> M0076-1 interposer <--> M0010 <--|
+--> M0010
Device Tree:
qcom,cam-sensor4qcom,cam-sensor5
J8 Pin-out
| 1 | GND | |
| 2 | GND | |
| 3 | CCI_I2C1_SDA | CAM1_CCI1_SDA, CAM4_CCI1_SDA, gpio103 |
| 5 | CCI_I2C1_SCL | CAM1_CCI1_SCL, CAM4_CCI1_SCL gpio104 |
| 7 | GND | |
| 9 | CSI4_CLK_CON_P | |
| 10 | GPIO_78_CAM4_RST_N | CAM4_RST_N, gpio78 |
| 11 | CSI4_CLK_CON_N | |
| 12 | GPIO_98_CAM_MCLK4 | CAM_MCLK4_CON, gpio98 |
| 13 | CSI4_LANE0_CON_P | LEFT |
| 14 | GND | |
| 15 | CSI4_LANE0_CON_N | LEFT |
| 16 | GPIO_112_CCI_TIMER3 | (unused in version 0) |
| 17 | GND | |
| 18 | GPIO_111_CCI_TIMER2 | CAM_FSYNC_5_OUT, CAM_FSYNC4_IN |
| 19 | CSI4_LANE1_CON_P | RIGHT |
| 20 | CAM_MCLK5_CON | CAM_MCLK5_CON, gpio99 |
| 21 | CSI4_LANE1_CON_N | RIGHT |
| 22 | VREG_PM8009_L6_2P8 | CAM4_AVDD_2P8, CAM5_AVDD_2P8 |
| 23 | CSI4_LANE2_CON_P | |
| 24 | GND | |
| 25 | CSI4_LANE2_CON_N | |
| 27 | GND | |
| 28 | CCI_I2C3_SDA | CAM5_CCI3_SDA, CAM3_CCI3_SDA, gpio107 |
| 29 | CSI4_LANE3_CON_P | |
| 30 | CCI_I2C3_SCL | CAM5_CCI3_SCL, CAM3_CCI3_SCL, gpio108 |
| 31 | CSI4_LANE3_CON_N | |
| 32 | MCLK6_G2_CON | (shared) CAM1_RST_N, gpio109 |
| 33 | GND | |
| 34 | GPIO_12_CAM2 | Not used as RTS, not available as GPIO |
| 35 | CSI5_CLK_CON_P | |
| 36 | GPIO_13_CAM2 | Not used as CTS, not available as GPIO |
| 37 | CSI5_CLK_CON_N | |
| 38 | GPIO_14_CAM2_UART5_TX | /dev/ttyHS0 |
| 39 | CSI5_LANE0_CON_P | |
| 40 | GPIO_15_CAM2_UART5_RX | /dev/ttyHS0 |
| 41 | CSI5_LANE0_CON_N | |
| 43 | GND | |
| 44 | GND | |
| 45 | CSI5_LANE1_CON_P | |
| 46 | VPH_PWR | |
| 47 | CSI5_LANE1_CON_N | |
| 48 | VPH_PWR | |
| 49 | CSI5_LANE2_CON_P | |
| 50 | GND | |
| 51 | CSI5_LANE2_CON_N | |
| 53 | GND | |
| 54 | GND | |
| 55 | CSI5_LANE3_CON_P | |
| 57 | CSI5_LANE3_CON_N | |
| 59 | GND | |
| 60 | GND |
J10 - External SPI
Available from apps proc as /dev/spidev14.0.
J10 Pin-out
| 1 | VREG_3P3V_LOCAL | 3.3V Power Output * |
| 2 | MISO (Input) | APPS_QUP_14, 3.3V signal levels |
| 3 | MOSI (Output) | APPS_QUP_14, 3.3V signal levels |
| 4 | SCLK (Output) | APPS_QUP_14, 3.3V signal levels |
| 5 | CS0_N (Output) | APPS_QUP_14, 3.3V signal levels |
| 6 | CS1_N/GPIO_46 (Output) | Second SPI CS_N or GPIO |
| 7 | 32K_CLK_OUT (Output) | 32kHz PMIC Sleep CLK, 3.3V signal levels |
| 8 | GND | GND |
J18 UART (ESC)
J18 ESC UART
| 2 | ESC_UART_TX (Output) | SSC_QUP_2, 3.3V signal levels. |
| 3 | ESC_UART_RX (Input) | SSC_QUP_2, 3.3V signal levels. |
| 4 | GND | GND |
SW Summary
Available from DSP as QUP2. In the factory configuration, PX4 communicates to the VOXL ESC through this UART.
J19 - External Sensors (2x UART/ 2x I2C)
J19 Pin-out
| 1 | VDC_5V_LOCAL | GNSS/Mag power * |
| 2 | GNSS TX 3P3V | slpi_proc, SSC_QUP6 |
| 3 | GNSS RX 3P3V | slpi_proc, SSC_QUP6 |
| 4 | MAG SCL 3P3V | slpi_proc, SSC_QUP0 |
| 5 | MAG SDA 3P3V | slpi_proc, SSC_QUP0 |
| 6 | GND | |
| 7 | I2C3 SDA 3P3V | slpi_proc, SSC_QUP3 |
| 8 | I2C3 SCL 3P3V | slpi_proc, SSC_QUP3 |
| 9 | VREG_3P3V_RC | RC power *, controllable via GPIO 159 |
| 10 | RC_UART_TX (Output) | slpi_proc, SSC_QUP7, 3.3V signal levels |
| 11 | RC_UART_RX (Input) | slpi_proc, SSC_QUP7, 3.3V signal levels |
| 12 | GND |
SW Summary
All connected to the DSP, and in the factory configuration are used as follows:
QUP0- I2C for external magnetomterQUP3- future useQUP6- UART for external GNSS (GPS)QUP7- UART for external RC input
Power Input/Output Important Note:
All power outputs on cable connectors are rated for 1A, however, the system cannot provide 1A simultaneously on all connectors. Contact ModalAI for design assistance.
The difference between VDCIN_5V and VDC_5V_LOCAL is very important. The power module provides VDCIN_5V (raw voltage input) to the platform. On-board is an eFuse that protects the system from accidental wrong-voltage application, droops/brown-outs, or down-stream shorts or overloads. The output of the eFuse is VDC_5V_LOCAL (i.e.: protected output).
