VOXL Vision PX4 Nuttx Shell
As long as voxl-vision-px4 is running, you can access PX4’s Nuttx shell with the voxl-px4-shell utility.
Note that this functionality is done through the Mavlink protocol. As such, your experience with the Nuttx shell with be much like that when accessing it through qGroundControl. There is no bash history in the Nuttx shell, so you can’t tap the ‘up’ arrow to go through recent commands.
This method is, however, a good alternative to starting qGroundControl when you need to access PX4’s Nuttx shell.
Interactive Mode
Simply run voxl-px4-shell with no arguments to start an interactive shell. Use Ctrl-C to exit the shell, not the exit command.
yocto:/# voxl-px4-shell
Welcome to PX4's Nuttx Shell
hit Ctrl-C to exit and return to VOXL
nsh>
nsh> param show BAT_*
Symbols: x = used, + = saved, * = unsaved
x BAT_A_PER_V [0,17] : -1.0000
x + BAT_CAPACITY [1,18] : 2200.0000
x + BAT_CRIT_THR [2,19] : 0.1000
x BAT_EMERGEN_THR [3,20] : 0.0500
x BAT_LOW_THR [4,21] : 0.1500
x + BAT_N_CELLS [5,22] : 4
x + BAT_R_INTERNAL [6,23] : 0.0080
x + BAT_V_CHARGED [7,24] : 4.1000
x BAT_V_DIV [8,25] : -1.0000
x + BAT_V_EMPTY [9,26] : 3.5000
x BAT_V_LOAD_DROP [10,27] : 0.3000
692/1286 parameters used.
nsh> param set BAT_CAPACITY 3000
+ BAT_CAPACITY: curr: 2200.0000 -> new: 3000.0000
nsh>
Sending Single Commands
If you are scripting something or just want to do something simple with one command, like set a parameter or restart px4, you can send that command in one of two ways:
yocto:/# voxl-px4-shell param set BAT_CAPACITY 3001
+ BAT_CAPACITY: curr: 3000.0000 -> new: 3001.0000
yocto:/#
Or, you can echo straight to the pipe which is what voxl-px4-shell is doing anyway:
yocto:/# echo "param set BAT_CAPACITY 3002" > /tmp/to_px4_shell
You can even read the response come back from the “from_px4_shell” pipe
yocto:/# cat /tmp/from_px4_shell
+ BAT_CAPACITY: curr: 3001.0000 -> new: 3002.0000
Common Commands
You should start by running the “help” command in nuttx to see all available programs and commands.
nsh> help
help usage: help [-v] [<cmd>]
[ cp export ls mw set true
? date false mkdir ps sh umount
break echo free mkfatfs pwd sleep unset
cat exec help mount rm test usleep
cd exit kill mv rmdir time
Builtin Apps:
esc_calib hott_telemetry mtd
hello adc land_detector
work_queue bmm150 serdis
perf iridiumsbd camera_trigger
sih hardfault_log roboclaw
tune_control bmi088 ms4525_airspeed
rgbled srf02 uavcan
pca9685 frsky_telemetry blinkm
bmp280 dataman safety_button
ets_airspeed landing_target_estimator motor_ramp
ak09916 pwm_out_sim led_control
reflect sf0x_tests hott_sensors
camera_feedback lis3mdl logger
uorb_tests mavlink pwm
dmesg sf1xx gps
hrt_test fw_att_control uorb
bst pga460 fmu
mkblctrl controllib_test ms5611
cm8jl65 bmp388 attitude_estimator_q
cdev_test tests ulanding_radar
rm3100 test_ppm qmc5883
ina226 sdp3x_airspeed airspeed_selector
param top mb12xx
motor_test dumpfile wqueue_test
ex_fixedwing_control sd_bench commander_tests
mixer px4_simple_app voxlpm
camera_capture listener tap_esc
hmc5883 px4_mavlink_debug sercon
local_position_estimator mpu6000 ll40ls
lsm303agr reboot vmount
rgbled_ncp5623c load_mon mc_att_control
send_event ekf2 mavlink_tests
tfmini navigator irlock
vl53lxx usb_connected bottle_drop
mc_pos_control mappydot fw_pos_control_l1
ver bl_update rover_steering_control
vtol_att_control ex_hwtest rover_pos_control
ms5525_airspeed i2cdetect uuv_example_app
ist8310 batt_smbus shutdown
config lps22hb nshterm
rc_input sf0x dshot
commander leddar_one
teraranger sensors
nsh>
Most of the time, you will probably use the nuttx shell to reboot PX4:
nsh> reboot
rebooting px4....
NuttShell (NSH)
nsh>
Or get and set parameters as demonstrated in the above sections.
Next
Next page: Other Features
