VOXL Supporting Software
This page is deprecated
Please see VOXL-SDK for our current software bundle.
VOXL’s software stack is broken up into 3 parts, each with their own version and ability to upgrade independently or all together.
  • VOXL System Image: This includes the root file system and bootloader partitions. It is only necessary to update the system image to add new hardware driver support.
  • VOXL Factory Bundle: This contains proprietary and 3rd party software packages (updated infrequently).
  • voxl-suite: precompiled packages of ModalAI-developed open-source software (updated regularly)
The System Image and Factory Bundle are available at https://developer.modalai.com/asset. The voxl-suite package uses an OPKG package manager and is hosted here. The installer at the link below will offer to install the voxl-suite for you as the last step.
All three packages are loaded on VOXL boards at the factory but can be updated by the user at any time using the instructions in VOXL Quickstarts.
voxl-suite
The voxl-suite packages are described and maintained here.
VOXL Factory Bundle
v1.0.1
Note: System Image 2.3.0+ is required to use Factory Bundle v1.0.1
Package list:
NamePackageNotes
aufs-utilaufs-util_3.14+git0+b59a2167a1-r0_aarch64.ipkRequired for Docker on VOXL
avahi-daemonavahi-daemon_0.6.31-r11.1_aarch64_js.ipk
cgroup-litecgroup-lite_1.1-r0_aarch64.ipkRequired for Docker on VOXL
royale-331-spectre-4-7latest_royale-331-spectre-4-7_0.0.1_8x96.ipkRequired for A65 Time-of-Flight
lib32-git-perltoolslib32-git-perltools_2.5.0-r0_armv7a-vfp-neon.ipk
libavahi-common3libavahi-common3_0.6.31-r11.1_aarch64.ipk
libavahi-core7libavahi-core7_0.6.31-r11.1_aarch64.ipk
libcgrouplibcgroup_0.41-r0_aarch64.ipkRequired for Docker on VOXL
libdaemon0libdaemon0_0.14-r0_aarch64.ipk
libncurseslibncursesw5_5.9-r15.1_aarch64.ipkRequired for Docker on VOXL
libnss-mdnslibnss-mdns_0.10-r7_aarch64.ipk
libsmartcolslibsmartcols1_2.26.2-r0_aarch64.ipkRequired for Docker on VOXL
libsystemdlibsystemd0_225+git0+e1439a1472-r0_aarch64Required for Docker on VOXL
Qualcomm Machine Vision SDKmv_1.2.8_8x96.ipkQualcomm Developer Network
ROS Indigo Build Depsros-indigo-build-deps_1.0.1.ipkSource
util-linuxutil-linux_2.26.2-r0_aarch64_js.ipkRequired for Docker on VOXL
util-linux-losetuputil-linux-losetup_2.26.2-r0_aarch64.ipkRequired for Docker on VOXL
util-linux-swaponoffutil-linux-swaponoff_2.26.2-r0_aarch64.ipkRequired for Docker on VOXL
util-linux-umountutil-linux-umount_2.26.2-r0_aarch64.ipkRequired for Docker on VOXL
voxl-utilsvoxl-utils_0.5.1.ipkSource
v0.0.3, v0.0.4, v0.0.5
Note: the factory version is bumped to stay in sync with software bundle version
Package list:
NamePackageNotes
ffmpegffmpeg_3.4.5_8x96_js.ipkSource
You can check the version of the VOXL Factory Bundle by looking at the version file.
cat /etc/modalai/voxl-factory-bundle-version.txt
0.0.5
VOXL Software Bundle
Note: as of System Image 2.3.0, this is considered legacy. It is replaced with the voxl-suite packages
V0.0.5
Changes:
  • Added support for ICM-42688 in imu_app_0.0.5_8x96.ipk for factory test
The package list:
NamePackageNotes
 cellular_tools_0.2.0_8x96.ipk
Dockerdocker_1.9.0+git…aarch64.ipk
IMU appimu_app_0.0.5_8x96.ipkSoon to be replaced by voxl-imu
RC Math Librarylibrc_math_1.0.1.ipkSource
VOXL IO Librarylibvoxl_io_0.0.6.ipkSource
ModalAI Vision Libmodalai-vl_0.1.0_8x96.ipk
VOXL Camera Managervoxl-cam-manager_0.2.1.ipkSource
VOXL Docker Supportvoxl-docker-support_1.1.0.ipkSource
VOXL IMUvoxl_imu_0.0.4_8x96.ipk
VOXL ROS Nodesvoxl-nodes_0.0.6_8x96.ipkSource
VOXL RTSPvoxl-rtsp_1.0.0_8x96.ipkSource
VOXL Utilsvoxl-utils_0.4.6.ipkSource
VOXL Vision PX4voxl-vision-px4_0.4.1_8x96.ipkSource
V0.0.4
Changes:
  • Improvements in voxl-vision-px4
The package list:
NamePackageNotes
V0.0.3
The package list:
NamePackageNotes
 cellular_tools_0.1.5_8x96.ipk
IMU appimu_app_0.0.3_8x96.ipkSoon to be replaced by voxl-imu
ModalAI Vision Libmodalai-vl_0.0.8_8x96.ipk
VOXL IMUvoxl_imu_0.0.3_8x96.ipk
VOXL Utilsvoxl-utils_0.4.4.ipkSource
VOXL Vision PX4voxl-vision-px4_0.4.0_8x96.ipkSource
Checking Version
Run the following command:
voxl-version
or you can check the version of the VOXL Software Bundle by looking at the version file:
cat /etc/modalai/voxl-software-bundle-version.txt
0.0.5
