VOXL Suite
VOXL Suite is the collection of VOXL SDK software packages that are installed on VOXL itself, as opposed to tools and build environments that are installed on a desktop. It is defined by a meta-package, voxl-suite_x.x.x.deb, that depends on all of the core ModalAI tools and services.
voxl-suite is bundled up with a matching system image to create what’s called a Platform Release.
Upgrade VOXL Suite Independently (Advanced)
It is highly recommended to stick to using Platform Releases as-is since they are tested as a whole with System Image and VOXL Suite together. If you are an experienced developer and know what you are doing then you can follow the instructions on the voxl-configure-pkg-manager page to configure VOXL to pull packages from different voxl-suite release, but we will not support software issues that arise from this.
CHANGELOG
v0.9.5
This is a maintenance release for SDK-0.9
- More robust writing to pipes
- Allow mavlink 1 packets through libmodal_pipe and voxl-mavlink-server
- voxl-mavlink-server can auto-select between 2 uart ports on APQ8096
- fix 3D map bug in voxl-portal
| Package | Version | APQ8096 | QRB5165 |
| apq8096-dfs-server | 0.3.1 (unchanged) | ✅ | |
| apq8096-imu-server | 1.0.3 (unchanged) | ✅ | |
| apq8096-libpng | 1.6.38-1 (unchanged) | ✅ | |
| apq8096-rangefinder-server | 0.1.3 (unchanged) | ✅ | |
| apq8096-system-tweaks | 0.1.3 (unchanged) | ✅ | |
| apq8096-tflite | 2.8.3-1 (unchanged) | ✅ | |
| libapq8096-io | 0.6.0 (unchanged) | ✅ | |
| libmodal-cv | 0.2.3 (unchanged) | ✅ | ✅ |
| libmodal-exposure | 0.0.7 (unchanged) | ✅ | ✅ |
| libmodal-journal | 0.2.1 (unchanged) | ✅ | ✅ |
| libmodal-json | 0.4.3 (unchanged) | ✅ | ✅ |
| libmodal-pipe | 2.6.0 –> 2.8.2 | ✅ | ✅ |
| libqrb5165-io | 0.1.0 (unchanged) | ✅ | |
| librc-math | 1.3.0 (unchanged) | ✅ | ✅ |
| libvoxl-cci-direct | 0.1.5 (unchanged) | ✅ | ✅ |
| libvoxl-cutils | 0.1.1 (unchanged) | ✅ | ✅ |
| mavlink-camera-manager | 0.1.0 (unchanged) | ✅ | |
| qrb5165-dfs-server | 0.1.0 (unchanged) | ✅ | |
| qrb5165-imu-server | 0.5.0 (unchanged) | ✅ | |
| qrb5165-system-tweaks | 0.1.5 (unchanged) | ✅ | |
| qrb5165-tflite | 2.8.0-2 (unchanged) | ✅ | |
| voxl-bind | 0.0.1 (unchanged) | ✅ | |
| voxl-camera-calibration | 0.2.3 (unchanged) | ✅ | ✅ |
| voxl-camera-server | 1.3.5 (unchanged) | ✅ | ✅ |
| voxl-ceres-solver | 1.14.0-9 (unchanged) | ✅ | ✅ |
| voxl-cpu-monitor | 0.3.0 (unchanged) | ✅ | ✅ |
| voxl-docker-support | 1.2.4 (unchanged) | ✅ | ✅ |
| voxl-eigen3 | 3.4.0 (unchanged) | ✅ | ✅ |
| voxl-flir-server | 0.2.0 (unchanged) | ✅ | ✅ |
| voxl-gphoto2-server | 0.0.10 (unchanged) | ✅ | ✅ |
| voxl-jpeg-turbo | 2.1.3-4 (unchanged) | ✅ | ✅ |
| voxl-libgphoto2 | 0.0.4 (unchanged) | ✅ | ✅ |
| voxl-libuvc | 1.0.7 (unchanged) | ✅ | ✅ |
| voxl-logger | 0.3.4 (unchanged) | ✅ | ✅ |
| voxl-mapper | 0.1.5 (unchanged) | ✅ | ✅ |
| voxl-mavlink | 0.1.0 (unchanged) | ✅ | ✅ |
| voxl-mavlink-server | 0.2.0 –> 0.3.0 | ✅ | ✅ |
| voxl-modem | 0.16.1 (unchanged) | ✅ | ✅ |
| voxl-mongoose | 7.7.0-1 (unchanged) | ✅ | ✅ |
| voxl-mpa-tools | 0.7.6 (unchanged) | ✅ | ✅ |
| voxl-mpa-to-ros | 0.3.6 (unchanged) | ✅ | ✅ |
| voxl-nlopt | 2.5.0-4 (unchanged) | ✅ | ✅ |
| voxl-opencv | 4.5.5-1 (unchanged) | ✅ | ✅ |
| voxl-portal | 0.4.2 –> 0.5.0 | ✅ | ✅ |
| voxl-px4 | 1.12.31 (unchanged) | ✅ | |
| voxl-px4-imu-server | 0.1.2 (unchanged) | ✅ | |
| voxl-qvio-server | 0.8.2 (unchanged) | ✅ | ✅ |
| voxl-remote-id | 0.0.5 (unchanged) | ✅ | |
| voxl-streamer | 0.4.1 (unchanged) | ✅ | ✅ |
| voxl-tag-detector | 0.0.4 (unchanged) | ✅ | ✅ |
| voxl-tflite-server | 0.3.1 (unchanged) | ✅ | ✅ |
| voxl-utils | 1.2.2 (unchanged) | ✅ | ✅ |
| voxl-uvc-server | 0.1.3 (unchanged) | ✅ | ✅ |
| voxl-vision-px4 | 1.4.0 (unchanged) | ✅ | ✅ |
| voxl-voxblox | 1.1.3 (unchanged) | ✅ | ✅ |
| voxl-vpn | 0.0.6 (unchanged) | ✅ |
v0.9.4
Requires VOXL (APQ8096) system image >= v4.0.0 and VOXL2/RB5F system image 1.4.1+
Major features:
IMU
* Improve stability of ICM42688 driver
* New Timestamp Filter module in librc_math
* improved timestamps in qrb5165-imu-server
* qrb5165-imu-server publishes live FFT of IMU data
* enable AAF filter for ICM42688 accel on QRB5165
Portal
* improve robustness un poor network conditions
* Image framerate and quality reacts more quickly
* new live FFT plot (qrb5165 only)
* better CPU and IMU plots
Camera
* PMD TOF support on both APQ8096 and QRB5165
Other
* VIO level calibration
* voxl-flir-server for Lepton 3 on both platforms
* VIO packet includes cam_id field for feature points
* point cloud packet includes ID and source fields
* QRB5165 more robust pipe disconnection detection
* voxl-mapper overhaul
* QRB5165 support external UART flight controller in voxl-mavlink-server
* VOA fallback mode when no VIO or attitude data is present
* QVIO quality metric based on distribution of features
* Preliminary (Beta) RemoteID support on QRB5165
| apq8096-dfs-server | 0.3.0 –> 0.3.1 | ✅ | |
| apq8096-imu-server | 1.0.2 –> 1.0.3 | ✅ | |
| apq8096-rangefinder-server | 0.1.2 –> 0.1.3 | ✅ | |
| apq8096-system-tweaks | 0.1.2 –> 0.1.3 | ✅ | |
| apq8096-tflite | 2.2.3-4 –> 2.8.3-1 | ✅ | |
| libapq8096-io | 0.5.8 –> 0.6.0 | ✅ | |
| libmodal-cv | 0.1.0 –> 0.2.3 | ✅ | ✅ |
| libmodal-journal | 0.2.1 (new) | ✅ | ✅ |
| libmodal-json | 0.4.2 –> 0.4.3 | ✅ | ✅ |
| libmodal-pipe | 2.4.0 –> 2.6.0 | ✅ | ✅ |
| librc-math | 1.1.8 –> 1.3.0 | ✅ | ✅ |
| libvoxl-cci-direct | 0.1.5 (new) | ✅ | ✅ |
| qrb5165-dfs-server | 0.0.5 –> 0.1.0 | ✅ | |
| qrb5165-imu-server | 0.2.4 –> 0.5.0 | ✅ | |
| qrb5165-system-tweaks | 0.1.3 –> 0.1.5 | ✅ | |
| voxl-camera-calibration | 0.2.2 –> 0.2.3 | ✅ | ✅ |
| voxl-camera-server | 1.1.0 –> 1.3.5 | ✅ | ✅ |
| voxl-ceres-solver | 1.14.0-7 –> 1.14.0-9 | ✅ | ✅ |
| voxl-cpu-monitor | 0.2.6 –> 0.3.0 | ✅ | ✅ |
| voxl-eigen3 | 3.4.0 (new) | ✅ | ✅ |
| voxl-flir-server | 0.0.4 –> 0.2.0 | ✅ | ✅ |
| voxl-libuvc | 1.0.6 –> 1.0.7 | ✅ | ✅ |
| voxl-logger | 0.3.2 –> 0.3.4 | ✅ | ✅ |
| voxl-mapper | 0.0.7 –> 0.1.5 | ✅ | ✅ |
| voxl-mavlink-server | 0.1.3 –> 0.2.0 | ✅ | ✅ |
| voxl-modem | 0.15.2 –> 0.16.1 | ✅ | ✅ |
| voxl-mongoose | 7.6.0 –> 7.7.0-1 | ✅ | ✅ |
| voxl-mpa-tools | 0.7.2 –> 0.7.6 | ✅ | ✅ |
| voxl-mpa-to-ros | 0.3.3 –> 0.3.6 | ✅ | ✅ |
| voxl-portal | 0.2.8 –> 0.4.2 | ✅ | ✅ |
| voxl-px4 | 1.4.16 –> 1.12.31 | ✅ | |
| voxl-qvio-server | 0.7.1 –> 0.8.2 | ✅ | ✅ |
| voxl-remote-id | 0.0.5 (new) | ✅ | |
| voxl-streamer | 0.3.6 –> 0.4.1 | ✅ | ✅ |
| voxl-tflite-server | 0.2.7 –> 0.3.1 | ✅ | ✅ |
| voxl-utils | 1.1.4 –> 1.2.2 | ✅ | ✅ |
| voxl-uvc-server | 0.1.1 –> 0.1.3 | ✅ | ✅ |
| voxl-vision-px4 | 1.2.0 –> 1.4.0 | ✅ | ✅ |
| voxl-voxblox | 1.0.4 –> 1.1.3 | ✅ | ✅ |
v0.8
Requires VOXL system image 3.8+ or VOXL2/RB5F system image 1.3.1+
This VOXL Suite is BETA only for VOXL 1 since it includes camera server updates allowing improved support for most cameras but no PMD TOF functionality
* IMPROVEMENT: apq8096 stereo cameras no longer have a high-pass filter and look much cleaner
* IMPROVEMENT: libmodal-cv beginning to support CVP functionality on QRB5
* IMPROVEMENT: libmodal-pipe support for setting process/thread priority
* IMPROVEMENT: libmodal-pipe/qvio/vvpx4 updated vio struct to match latest mavlink
* IMPROVEMENT: voxl-camera-calibration command line options for more modular use
* IMPROVEMENT: voxl-camera-server support for ov9782 cameras
* IMPROVEMENT: voxl-logger major efficiency rework
* NEW PACKAGE: voxl-bind (qrb5165-only)
* RENAME PACKAGE: qrb5165-camera-server > voxl-camera-server (now cross-platform)
| apq8096-dfs-server | 0.2.6 –> 0.3.0 | ✅ | |
| apq8096-imu-server | 1.0.1 –> 1.0.2 | ✅ | |
| apq8096-libpng | 1.6.38-1 (new) | ✅ | |
| apq8096-rangefinder-server | 0.1.0 –> 0.1.2 | ✅ | |
| apq8096-system-tweaks | 0.1.2 (unchanged) | ✅ | |
| apq8096-tflite | 2.2.3-4 (unchanged) | ✅ | |
| libapq8096-io | 0.5.8 (unchanged) | ✅ | |
| libmodal-cv | 0.0.5 –> 0.1.0 | ✅ | ✅ |
| libmodal-json | 0.4.2 (unchanged) | ✅ | ✅ |
| libmodal-pipe | 2.1.7 –> 2.4.0 | ✅ | ✅ |
| librc-math | 1.1.8 (unchanged) | ✅ | ✅ |
| mavlink-camera-manager | 0.0.6 –> 0.1.0 | ✅ | |
| qrb5165-dfs-server | 0.0.4 –> 0.0.5 | ✅ | |
| qrb5165-imu-server | 0.2.0 –> 0.2.4 | ✅ | |
| qrb5165-system-tweaks | 0.1.2 –> 0.1.3 | ✅ | |
| voxl-bind | 0.0.1 (new) | ✅ | |
| voxl-camera-calibration | 0.1.5 –> 0.2.2 | ✅ | ✅ |
| voxl-camera-server | 1.1.0 (new) | ✅ | ✅ |
| voxl-ceres-solver | 1.14.0-5 –> 1.14.0-7 | ✅ | ✅ |
| voxl-cpu-monitor | 0.2.5 –> 0.2.6 | ✅ | ✅ |
| voxl-gphoto2-server | 0.0.10 (unchanged) | ✅ | |
| voxl-libuvc | 1.0.6 (unchanged) | ✅ | ✅ |
| voxl-logger | 0.1.2 –> 0.3.2 | ✅ | ✅ |
| voxl-mapper | 0.0.6 –> 0.0.7 | ✅ | ✅ |
| voxl-mavlink | 0.0.7 –> 0.1.0 | ✅ | ✅ |
| voxl-mavlink-server | 0.1.1 –> 0.1.3 | ✅ | ✅ |
| voxl-modem | 0.15.1 –> 0.15.2 | ✅ | ✅ |
| voxl-mongoose | 7.6.0 (unchanged) | ✅ | ✅ |
| voxl-mpa-tools | 0.6.3 –> 0.7.2 | ✅ | ✅ |
| voxl-mpa-to-ros | 0.3.2 –> 0.3.3 | ✅ | ✅ |
| voxl-portal | 0.2.6 –> 0.2.8 | ✅ | ✅ |
| voxl-px4 | 1.4.16 (new) | ✅ | |
| voxl-px4-imu-server | 0.1.1 –> 0.1.2 | ✅ | |
| voxl-qvio-server | 0.4.6 –> 0.7.1 | ✅ | ✅ |
| voxl-streamer | 0.3.1 –> 0.3.6 | ✅ | ✅ |
| voxl-tflite-server | 0.2.3 –> 0.2.7 | ✅ | ✅ |
| voxl-utils | 1.1.1 –> 1.1.4 | ✅ | ✅ |
| voxl-uvc-server | 0.1.1 (unchanged) | ✅ | ✅ |
| voxl-vision-px4 | 1.0.5 –> 1.2.0 | ✅ | ✅ |
| voxl-voxblox | 1.0.3 –> 1.0.4 | ✅ | ✅ |
v0.7.0
Requires VOXL system image 3.8+ or VOXL2 system image 1.2.1+
This is the first SDK release with support for both VOXL (APQ8096) and VOXL2 (QRB5165). Every package has been updated with dual-platform support (where applicable) and the entire SDK is now built via CI.
Starting with V0.7.0, the new SDK repository is hosted at http://voxl-packages.modalai.com/dists/.
* RENAME PACKAGE: voxl-camera-server > apq8096-camera-server (apq8096 only)
* RENAME PACKAGE: voxl-imu-server > apq8096-imu-server (apq8096 only)
* RENAME PACKAGE: libvoxl_io > libapq8096-io (apq8096 only)
* NEW PACKAGE: qrb5165-camera-server (qrb5165-only)
* NEW PACKAGE: qrb5165-imu-server (qrb5165-only)
* NEW PACKAGE: qrb5165-dfs-server (qrb5165-only)
* NEW PACKAGE: libmodal-cv
* NEW PACKAGE: voxl-mavlink-server
* NEW PACKAGE: voxl-px4-imu-server (qrb5165 only)
* NEW PACKAGE: libqrb5165-io (qrb5165-only)
* NEW PACKAGE: qrb5165-tflite (qrb5165-only)
* NEW PACKAGE: voxl-px4 (qrb5165-only)
* IMPROVEMENT: voxl-camera-calibration accuracy and usability
* IMPROVEMENT: voxl-vision-px4 talks to PX4 through voxl-mavlink-server
* IMPROVEMENT: voxl-portal: dynamic image quality, point cloud viewer
* CLEANUP: Remove old wizard from voxl-configure-mpa
* NEW TOOL: voxl-configure-pkg-manager
v0.5.0
Requires VOXL system image 3.3+
* NEW TOOL: voxl-calibrate-cameras utility
* NEW TOOL: imu thermal calibration
* NEW TOOL: voxl-configure-opkg
* NEW TOOL: voxl-calibrate-px4-horizon tool
* NEW TOOL: voxl-portal web interface
* NEW TOOL: voxl-wait-for-fs service
* NEW TOOL: voxl-list-pipes
* ADDITION: libmodal_pipe pause-resume function
* ADDITION: voxl-configure extrinsics add support for Starling
* ADDITION: voxl-mpa-to-ROS dynamic pipe detection (no more config!!)
* IMPROVEMENT: file system syncs more frequently
* IMPROVEMENT: voxl-qvio-reset is more complete
* IMPROVEMENT: voxl-configure cameras wizard tweaks
* IMPROVEMENT: voxl-configure-mpa support new part numbers
* IMPROVEMENT: voxl-inspect-services speedup
* IMPROVEMENT: too many little tweaks and fixes to list
| Package | Package Version |
| libjpeg_turbo | 9.0.4+ |
| libmodal_exposure | 0.0.2+ |
| libmodal_json | 0.3.6+ |
| libmodal_pipe | 2.1.1+ |
| librc_math | 1.1.5+ |
| libvoxl_cutils | 0.0.2+ |
| libvoxl_io | 0.5.4+ |
| mavlink-camera-manager | 0.0.2+ |
| mongoose | 7.3.0+ |
| opencv | 4.5.2-2+ |
| openmp | 10.0.2+ |
| voxl-camera-calibration | 0.1.1+ |
| voxl-camera-server | 0.7.1+ |
| voxl-cpu-monitor | 0.2.0+ |
| voxl-dfs-server | 0.2.2+ |
| voxl-docker-support | 1.1.3+ |
| voxl-gphoto2 | 0.0.5+ |
| voxl-imu-server | 0.9.1+ |
| voxl-mavlink | 0.12.0+ |
| voxl-modem | 0.0.2+ |
| voxl-mpa-tools | 0.3.6+ |
| voxl-nodes | 0.2.0+ |
| voxl-portal | 0.1.1+ |
| voxl-qvio-server | 0.3.4+ |
| voxl-streamer | 0.2.6+ |
| voxl-tag-detector | 0.0.2+ |
| voxl-tflite | 2.2.3+ |
| voxl-tflite-server | 0.1.5+ |
| voxl-utils | 0.8.4+ |
| voxl-vision-px4 | 0.9.5+ |
| voxl-vpn | 0.0.3+ |
v0.4.6
Requires System Image 3.3+
Contains the following packages:
| voxl-utils | 0.7.1+ |
| voxl-mpa-tools | 0.2.6+ |
| libmodal_json | 0.3.5+ |
| libmodal_pipe | 2.0.7+ |
| opencv | 4.5.2-1+ |
| openmp | 10.0.2+ |
| voxl-cpu-monitor | 0.1.7+ |
| voxl-dfs-server | 0.2.0+ |
| voxl-imu-server | 0.8.1+ |
| voxl-modem | 0.12.0+ |
| voxl-nodes | 0.1.6+ |
| voxl-qvio-server | 0.3.1+ |
| voxl-streamer | 0.2.3+ |
| voxl-tflite(no repo) | 0.0.1+ |
| voxl-tflite-server | 0.1.0+ |
| voxl-vision-px4 | 0.9.2+ |
| voxl-vpn | 0.0.3+ |
v0.3.4
Requires System Image 3.2+
| voxl-utils | 0.6.0+ |
| libmodal_json | 0.3.4+ |
| libmodal_pipe | 1.7.8+ |
| librc_math | 1.1.4+ |
| mavlink-camera-manager | 0.0.1+ |
| opencv | 4.5.1+ |
| openmp | 10.0.1+ |
| voxl-camera-server | 0.5.6+ |
| voxl-dfs-server | 0.0.7+ |
| voxl-docker-support | 1.1.1+ |
| voxl-hal3-tof-cam-ros | 0.0.5+ |
| voxl-imu-server | 0.7.8+ |
| voxl-modem | 0.11.0+ |
| voxl-mpa-tflite-server | 0.0.2+ |
| voxl-mpa-tools | 0.1.6+ |
| voxl-nodes | 0.1.0+ |
| voxl-qvio-server | 0.2.1+ |
| voxl-rtsp | 1.0.3+ |
| voxl-streamer | 0.2.1+ |
| voxl-vision-px4 | 0.8.1+ |
| voxl-vpn | 0.0.3+ |
v0.2.0
Changes:
- Updated
voxl-vision-px4, PX4 disconnect detection, better handling of ‘CRC errors’, UART port and baud configurable, keep publishing data if VIO is off, wizard improvements - Updated
voxl-modem, added LTE v2 support - Updated
voxl-utils, addedvoxl-backuputil for camera calibration backup - Added new
voxl-vpnpackage - Added new
voxl-time-syncpackage - Removed ffmpeg as it’s normally used via Docker containers
| docker | 1.9.0 |
| imu_app | 0.0.6 |
| libmodal_pipe | 1.2.2 |
| librc_math | 1.1.2 |
| modalai-vl | 0.1.3 |
| libvoxl_io | 0.5.2 |
| voxl-cam-manager | 0.2.2 |
| voxl-docker-support | 1.1.1 |
| voxl-hal3-tof-cam-ros | 0.0.2 |
| voxl-modem | 0.10.0 |
| voxl-nodes | 0.0.8 |
| voxl-rtsp | 1.0.2 |
| voxl-time-sync | 0.0.1 |
| voxl-utils | 0.5.2 |
| voxl-vision-px4 | 0.6.8 |
| voxl-vpn | 0.0.2 |
| voxl_imu | 0.0.4 |
Tested against:
- System Image 2.5.2-1.0.1
- System Image 2.3.0-1.0.1
v0.1.1
| Package | Package Version (min) |
| docker | 1.9.0 |
| ffmpeg | 4.2.2 |
| imu_app | 0.0.6 |
| libvoxl_io | 0.4.1 |
| libvoxl_pipe | 1.0.1 |
| voxl-modem | 0.9.3 |
| voxl-rtsp | 1.0.2 |
| voxl-utils | 0.5.1 |
| voxl-vision-px4 | 0.6.1 |
| voxl_imu | 0.0.4 |
Tested against: System Image 2.3.0-1.0.1
