VOXL Modem
voxl-modem is a tool which enables modem usage for the following hardware:
- ModalAI LTE v1 (WNC CSS Modules, apq8096 only)
- ModalAI LTE v2 (Sierra Modules)
- 5G (Quectel)
- Doodle Labs (Helix Radio)
- Microhard
Installation
voxl-modem is installed via ipk package.
opkg update
opkg install voxl-modem
When using modem related hardware it is recommended to be on the latest platform release.
Running voxl-modem
A one time configuration script, voxl-configure-modem is required to do first time setup. This can be ran via. the command line on any VOXL product:
voxl2:/$ voxl-configure-modem
Making new config file /etc/modalai/voxl-modem.conf
1) v2
2) microhard
3) doodle
4) quectel
This script will take you through a number of questions in order to setup your modem hardware and enable the voxl-modem systemd service.
Depending on which VOXL hardware you’re using the available options may vary.
User Guides and Datasheets
| User Guide | Datasheet | |
| ModalAI LTE v1 | LTE v1 User Guide | LTE v1 Datasheet |
| ModalAI LTE v2 | LTE v2 User Guide | LTE v2 Datasheet |
| 5G (Quectel) | 5G User Guide | M0090 Datasheet |
| Doodle Labs | Doodle Labs User Guide | Doodle Labs Datasheet |
| Microhard | Microhard User Guide | Microhard Datasheet |
