VOXL List Pipes
voxl-list-pipes is a Simple tool to list all of the MPA pipes currently available in the system. Running the command alone is identical to the command ls /run/mpa, but when giving it the -t or --mode-types flag, it will sort the pipes by type, allowing you to easily see which cameras/imus/etc are available in the system.
Example Output:
yocto:/$ voxl-list-pipes -t
camera_image_metadata_t
hires
qvio_overlay
tof_conf
tof_depth
tof_ir
tof_noise
tracking
cpu_stats_t
cpu_monitor
imu_data_t
imu0
imu1
mavlink_message_t
vvpx4_gps_raw_int
vvpx4_mavlink_io
vvpx4_sys_status
vvpx4_vehicle_gps
point_cloud_metadata_t
tof_pc
pose_vel_6dof_t
vvpx4_body_wrt_fixed
vvpx4_body_wrt_local
qvio_data_t
qvio_extended
text
vvpx4_shell
tof_data_t
tof
vio_data_t
qvio
yocto:/$
Source:
The source code for this can be found here
