How to Control Fan on VOXL
Connect the Fan
Connect the cooling fan rated for 5V to J6 (see VOXL Connectors)
Control the Fan with the voxl-fan utility
[voxl-cpu-monitor/(voxl-cpu-monitor) monitors the CPU temperature and adjust the fan control accordingly.
The voxl-utils package (>= v0.5.8) includes a utility voxl-fan to control the fan speed.
yocto:/# voxl-fan --help
General Usage:
voxl-fan on
voxl-fan slow
voxl-fan off
The fan is on at full speed when voxl boots. It can be slowed down to half speed with voxl-fan slow or turned off completely with voxl-fan off.
Control the Fan PWM driver directly
# Spin the fan using 25kHz PWM, 50% duty cycle
PWM_DEVICE=/sys/class/pwm/pwmchip0
echo 0 >     ${PWM_DEVICE}/export
echo 40000 > ${PWM_DEVICE}/pwm0/period
echo 20000 > ${PWM_DEVICE}/pwm0/duty_cycle
echo 1 >     ${PWM_DEVICE}/pwm0/enable
Notes
- The fan turns on at full power when the board is turned on
- The periodandduty_cyclenumbers are in microseconds
- PWM Switching Frequency (kHz) = 1000000 / period
- PWM duty_cycleshould be in the range of [0..period]
- Only several discrete frequencies are possible : 12.5khz, 15.00khz 18.75khz, 25khz, 30.00khz, 37.5khz, 50khz
- The requested period gets rounded off or truncated to pick one of these frequencies
