voxl-elrs
What is ExpressLRS?
ExpressLRS (ELRS) aims to provide the best completely open, high refresh radio control link while maintaining a maximum achievable range at that rate with low latency. Vast support of hardware in both 900 MHz and 2.4 GHz frequencies using the crossfire protocol.
What is voxl-elrs?
voxl-elrs is an application which gives a user the ability to flash a receiver or transmitter, put a receiver into bind mode, and get device information from a receiver.
There is a large array of ELRS compatible receivers and transmitters on the market and we haven’t tested them all, but below is a list of some that we know voxl-elrs supports.
In theory, voxl-elrs supports any receiver that is compatible with ELRS, however some functionalities such as setting a receiver into bind mode may be deprecated since this action requires firmware modifications. Here is a list of currently supported receivers and transmitters:
Receivers:
- BetaFPV Nano 900MHz
Transmitters:
- iFlight Commando 8
Usage
Currently, voxl-elrs does not require any configuration in order to get started. Usage is as follows:
voxl2:/$ voxl-elrs -h
Description: Flash a RX or TX with ELRS firmware.
Usage: voxl-elrs -h -d -w -q -b -v -s
Optional Arguments:
-h, --help Show this help message and exit
-d, --device Serial port to use for flashing
-w, --wizard Activate interactive wizard
-q, --quiet Quiet mode, don't print msgs
-b, --bind Put receiver in bind mode
-v, --version Get receiver version information
-s, --scan Scan receiver for firmware information
Argument Descriptions:
- -h/–help: Show the help message and exit.
- -d/–device: Specify a specific serial port to use when flashing a receiver or transmitter. By default, this will be set to /dev/ttyUSB0 if flashing a transmitter and /dev/slpi-uart-7 when flashing a receiver through voxl2.
- -w/–wizard: Activate the interactive wizard that provide user options.
- -q/–quiet: Quiet mode, don’t print out any messages. Voxl-elrs program will not print out any messages but underlying programs that are called may still print some messages.
- -b/–bind: Set a receiver that has been flashed with ModalAI firmware into bind mode.
- -v/–version: Get version information from a receiver. This includes receiver name (Ex: BetaFPV 900RX) and firmware version (Ex: 3.2.1.1).
- -s/–scan: Scan a connected receiver for firmware information, automatically update to latest firmware if detected version is out of date.
Tips
- The recommended usage of this tool is to use the interactive wizard, by either using
voxl-elrs -worvoxl-elrs --wizardand then following the prompt. - If you just want to bind a transmitter to your receiver, you can use the
voxl-bind-elrshelper utility which will set the receiver into bind mode without having to use the wizard.- Note: You cannot set a receiver into bind mode if it is actively connected to a transmitter. Turn the transmitter off and then run either
voxl-bind-elrs,voxl-elrs --bind, or run the wizard and follow the prompt for bind mode.
- If making your own custom modifications to the receiver firmware then be careful using the
voxl-elrs --scanfunction unless you update the firmware version number to be higher than the current ModalAI firmware version (3.2.1.1 as of 6/22/2023). - You can determine the state of the receiver by inspecting the LED on your receiver and comparing to the information on the ELRS LED Status page.
- Useful information regarding all things ExpressLRS (ELRS) can be found on the ELRS quickstart page.
