VOXL 2 Hardware Quickstart
NOTE: Please exercise ESD safety precautions and have electronics knowledge when interfacing with the hardware.
How to Setup Hardware
- Connect power cable to VOXL 2
J4 - Connect other side of power cable to Power Module
- Connect USBC cable to VOXL 2
J9 - Connect other side of USBC cable (recommmended USB type A) to host computer
- Connect Power Module to the wall wart power supply
- Plug wall wart power supply into mains supply
Three LEDs should illuminate GREEN (LED details found here).
How to Power Off
