Thermal and Performance
Resources for debugging thermal performance on VOXL platform
VOXL, and all Snapdragon platforms, use frequency scaling to control thermal and try to maximize performance. The VOXL will limit maximum frequency if the SoC becomes too hot. Therefore it is important to manage resources carefully, like in all embedded platforms. A good article on thermal frequnecy scaling can be found here.
This page is dedicated to some of the tools available on VOXL to manage performance.
Mechanical solutions, such as a fan or a heatsink, help maximize performance. We have found this 5g cooling fan to have a good tradeoff in performance and weight.
voxl-inspect-cpu
voxl-inspect-cpu is a useful tool for monitoring CPU and GPU utilization and core temperatures.
voxl-perfmon
(deprecated in favor of voxl-inspect-cpu)
A Python script to monitor CPU and GPU usage as well as individual core temperatures called voxl-perfmon is bundled in the voxl-utils package that is installed by default on the target.
Commands
Governor
Set CPU 0 to performance mode
$ echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
View CPU 0’s governor mode
$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
Set GPU to performance mode
$ echo performance > /sys/class/kgsl/kgsl-3d0/devfreq/governor
View GPU’s governor mode
$ cat /sys/class/kgsl/kgsl-3d0/devfreq/governor
Other CPU Governor Options
| Governor | Description |
| performance | Run the CPU at the maximum frequency. |
| powersave | Run the CPU at the minimum frequency. |
| userspace | Run the CPU at user specified frequencies. |
| ondemand | Scales the frequency dynamically according to current load. Jumps to the highest frequency and then possibly back off as the idle time increases. |
| conservative | Scales the frequency dynamically according to current load. Scales the frequency more gradually than ondemand. |
Frequency
View CPU 0’s current frequency
$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
View CPU 0’s minimum frequency
$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
View CPU 0’s maximum frequency
$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
View CPU 3’s available frequencies for scaling
$ cat /sys/devices/system/cpu/cpu3/cpufreq/scaling_available_frequencies
$ 307200 403200 480000 556800 652800 729600 806400 883200 940800 1036800 1113600 1190400 1248000 1324800 1401600 1478400 1555200 1632000 1708800 1785600 1824000 1920000 1996800 2073600 2150400
Set CPU 3’s maximum frequency to 1785600 in the governor
$ echo 1785600 > /sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq
View GPU’s current frequency
cat /sys/class/kgsl/kgsl-3d0/devfreq/cur_freq\
View GPU’s minimum frequency
$ cat /sys/class/kgsl/kgsl-3d0/devfreq/min_freq
View GPU’s maximum frequency
cat /sys/class/kgsl/kgsl-3d0/devfreq/max_freq
View GPU’s available frequencies
$ cat /sys/class/kgsl/kgsl-3d0/devfreq/available_frequencies
$ 3133000000 214000000 315000000 401800000 510000000 560000000 624000000
Set GPU’s maximum frequency to 560000000 in the governor
$ echo 560000000 > /sys/class/kgsl/kgsl-3d0/devfreq/max_freq
Online
See which CPU’s are online
$ cat /sys/devices/system/cpu/online
Set CPU 2 offline
$ echo 0 > /sys/devices/system/cpu/cpu2/online
Next: USB to Ethernet with VOXL
