Starling v2 Hardware Quickstart
Quickstart Video
1. Ensure propellor clips are installed:
2. Connect USB-C Cable
- Connect USB-C cable to VOXL 2
- Connect other side of USB-C cable (recommmended USB type A) to host computer for later use
3. Power ON
- Connect the battery or wall power supply to the XT30 connector (labeled
Powerabove)
The development drone will bootup and make play a jingle via the ESC.
How to Power Off
