SSH to VOXL
Instructions
If your host computer is on the same network as the VOXL, you can SSH into it.
If the VOXL is setup as a Soft AP, the IP address is 192.168.8.1, otherwise you’ll need to find it’s IP address with ifconfig as described in the previous step.
me@mylaptop:~$ ssh root@192.168.8.1
(password: oelinux123)
Later, in the ROS Host PC Setup Instructions, you will configure an alias to speed up the ssh process.
Known Running ROS Through SSH
