Setup ADB
The following describes how to setup the Android Debug Bridge (ADB) tool on a host computer. This tool is used to facilitate communications and file transfers between the VOXL and the host computer.
Host Computer Setup
ModalAI Top Tip: to run ADB without root on the host PC, create a file called /etc/udev/rules.d/51-android.rules
containing this udev rule on the host computer:
me@mylaptop:~$ sudo su
root@mylaptop:/home/me# echo 'SUBSYSTEM=="usb", ATTRS{idVendor}=="05c6", ATTRS{idProduct}=="901d", MODE="0660", GROUP="plugdev", SYMLINK+="voxl%n"' > /etc/udev/rules.d/51-android.rules
root@mylaptop:/home/me# echo 'SUBSYSTEM=="usb", ATTRS{idVendor}=="18d1", ATTRS{idProduct}=="d00d", MODE="0660", GROUP="plugdev", SYMLINK+="voxl-fastboot%n"' >> /etc/udev/rules.d/51-android.rules
root@mylaptop:/home/me# udevadm control --reload-rules && udevadm trigger
Common ADB Commands
Listed here for convenience are some common ADB commands.
Check for Devices
From the host, you can check for connected devices using adb devices
me@mylaptop:~$ adb devices
List of devices attached
73a05d48 device
Access the Shell
You can gain access to VOXL’s shell from the host computer using adb shell
me@mylaptop:~$ adb shell
This will start an sh shell. Generally you want to use a bash shell instead, so we recommend starting bash right away. Running adb shell
followed by starting ‘bash’ will look like this:
/ # bash
yocto:/#
You should see the ‘yocto’ prompt after starting bash. To confirm, you can also look at the SHELL
variable:
yocto:/# echo $SHELL
/bin/bash
Exit out of adb shell
Just use the exit
command to exit. If you started a bash shell inside the sh shell as described above, you will need to run exit twice to exit out of each. The process to start a shell, start bash, and exit again looks like this:
/ # bash
yocto:/# echo "I am inside VOXL!"
I am inside VOXL!
yocto:/# exit
exit
/ # exit
me@mylaptop:~$
Run Something Once with adb shell <command>
If you don’t want to start an interactive shell, but just want to run one command on VOXL, you can pass the command directly to adb shell
me@mylaptop:~$ adb shell echo "I am inside VOXL"
I am inside VOXL
me@mylaptop:~$
Wait for Device
A useful command for creating scripts for host-to-target communications is this one that sits and waits until a device is connected:
me@mylaptop:~$ adb wait-for-device
Copying Files
You can copy files to/from VOXL (similar to scp
) using the adb push
and adb pull
commands.
For example, to copy /temp/test.dat
to the VOXL at /
me@mylaptop:~$ adb push /tmp/test.dat /
/tmp/test.dat: 1 file pushed.
To copy it back from the VOXL at /test.dat
to /temp
me@mylaptop:~$ adb pull /test.dat /tmp
/test.dat: 1 file pulled
Reboot VOXL
You can reboot VOXL with a single adb command adb reboot
. This is often followed by adb wait-for-device
which returns when VOXL has finished rebooting.
me@mylaptop:~$ adb reboot
