Documentation for ModalAI’s range of flex cables and adapters that connect VOXL, RB5 Flight and VOXL 2 to various image sensor modules.
Extending MIPI Image Sensor Cable Lenghts
It is strongly recommended to not connect multiple flex cables back-to-back to increase length beyond what ModalAI has shipped as a valid and supported configuration. The risk here includes:
- Incorrect connector orientation risk resulting in sensor or Voxl failures (including power to ground shorts)
- Adding mating cycles to connectors that have limited life span
- Reducing reliability due to increased interconnect points
- Increasing the length or creating a configuration beyond the data link limits ModalAI has already proven and supports
If your application needs an extended length for your image sensor, please contact ModalAI and we can explore a custom flex/cable hardware and software solution that will work for you.
Image Sensor Flex Catalog
| NUMBER | DESCRIPTION | WEIGHT | 3D Model | BUY | DATASHEET |
| M0008 | DFT Interposer Flex | Datasheet | |||
| M0010 | Stereo Flex | Buy | Datasheet | ||
| M0036 | 14.5cm Extension Flex | Buy | Datasheet | ||
| M0074 | 6mc Extension Flex | Buy | Datasheet | ||
| M0084 | VOXL 2 Y-Flex | Buy | Datasheet | ||
| M0109 | VOXL 2 J-Flex | Datasheet | |||
| M0135 | VOXL 2 Dual-cam Adapter | Datasheet |
