This page will host a variety of hardware topics relevant to Hardware Engineers that are designing image sensor components relating to our Voxl ecosystem. Image sensor flex cables, adapter boards, and modules are hard to get right. There are many topics that must be well understood in order to have success the first time, and every time.
The range of applications covered here will include, but are not limited to:
- MIPI CSI fundamental aspects
- Voxl based MIPI CSI Architectures
- Voxl/Voxl-Flight vs Voxl2 vs Voxl2 Mini
- Common Image Sensor specifications
- ModalAI’s new Computer Vision SW Framework definitions (only applicable to Voxl2+, not Voxl)
- Schematic Conventions & the “do’s and don’ts” of electrical design for MIPI CSI
- Flexes vs Rigid PCB design and the tradeoffs why/when each is selected
- Key things to know when working with your Mechanical Engineering team
- bend radius, clearances, pin 1’s
- Complete Schematic Examples (RB5 flight Flexes and Voxl-Cam rigid PCB)
- HighSpeed Routing Constraints
- Impedance Control, Length Limits, Via Structures and routing tips
- Manufacturing Tips and Tricks for Flexes and Rigid PCBs
- Layer Stackups
- EMI coating
- Ground planes, solid vs hatching
- Testing
and lastly, if this all becomes too overwhelming:
- How to contract ModalAI to do your flexes for you
- What info is needed
- Our typical process and turn-around times
Application Note Outline
MIPI CSI Overview
PENDING, TBD, etc etc… this will all take some time. Please check back often.
Voxl MIPI CSI Architectures
If there are certain topics you want to see first on that list above, please reach out on the Forum and add the tag “Image Sensor Hardware Design and Integration Guide” in your topic so we can prioritize our responses
