Flight Core v2 Firmware
Release Notes
| Version | Type | Change Description | Commit | Status |
| v1.13.3-0.0.1 | ModalAI Enhancement | - move ModalAI ESC default port from J1 to J5 for Seeker - cherry pick updates from PX4 1.13.3 release | Tag | pending |
| v1.13.2-0.1.1 | ModalAI Enhancement | - Initial release on top of v1.13.2 from PX4 mainline | Tag | Released |
General User Guide
QGroundControl FW Update
The FW update feature in QGC requires QGC Daily starting with the 2023-04-19 daily build.
It will be included in the next QGC release, but until then, you will need to download and use the daily build of QGC.
How to Upgrade using px_uploader Tool
Alternatively, to update the firmware, you can use the px_uploader tool.
This has been tested on OSX 13.1, Ubuntu 18.04, and Ubuntu 22.04 with success to update firmware over USB.
- Ensure you have Python 3 and
pyserialmodule installed (pip3 install pyserial) - Follow build guide below, or download the firmware from links above in release notes (e.g. modalai_fc-v2_default.px4)
- Obtain the PX4 open source community tool (not a ModalAI tool):
git clone -b modalai-1.13.2 https://github.com/modalai/px4-firmware.git --recursive
cd px4-firmware
- Exit QGC if running
- Disconnect Flight Core v2 from USB
- Run the following (note: your USB device name may be different and your path may be different, Linux default is
/dev/ttyACM1, OSX default is/dev/cu.usbmodem01)
./Tools/px_uploader.py --port /dev/ttyACM1 modalai_fc-v2_default.px4 --baud-bootloader 1152000
- Connect Flight Core v2 over USB (note, no external power needed)
- Flight Core v2 boots into bootloader mode
- The update should now begin
Developer Guide
v1.13.3 PX4 Support
ModalAI makes some mods to mainline and maintains a branch here that is shipped on the product by default.
Mainline Support
- PX4 mainline Board Support is available at boards/modalai/fc-v2
Tools for Flashing
Recommended hardware: similar to STLink v2 or equivalent. Please install STM32CubeProgrammer to get the STM32_Programmer_CLI binary.
How to Build PX4 Application
git clone -b modalai-1.13.3 https://github.com/modalai/px4-firmware.git --recursive
cd px4-firmware
make modalai_fc-v2
After building, the bootloader binary is located at:
build/modalai_fc-v2_default/modalai_fc-v2_default.bin
How to Flash PX4 Bootloader with ST32CubeProgrammer
The application is flashed at 0x08020000:
echo "programming application..."
STM32_Programmer_CLI -c port=SWD -w modalai_fc-v2_default.bin 0x08020000 -v
Bootloader
The bootloader is flashed at the factor and generally you do not need to build or flash it. But, if you want to customize the bootloader, the following can be used.
How to Build PX4 Bootloader
cd px4-firmware
make modalai_fc-v2_bootloader
build/modalai_fc-v2_bootloader/modalai_fc-v2_bootloader.bin
The bootloader is flashed at 0x08000000:
echo "erasing..."
STM32_Programmer_CLI -c port=SWD -e all
echo "programming bootloader..."
STM32_Programmer_CLI -c port=SWD -w modalai_fc-v2_bootloader.bin 0x08000000 -v
