Flight Core Connectors
- Board Connections and Pin-out Specifications
- J1 - VOXL Communications Interface Connector
- J2 - Programming and Debug Console
- J3 - USB Connector
- J4 - UART ESC, UART2/TELEM3
- J5 - Telemetry Connector
- J6 - VOXL-Power Management Input / Expansion
- J7 - 8-Channel PWM Output Connector for PWM or DShot ESCs
- J8 - CAN Bus Connector
- J9 - PPM RC In
- J10 - External GPS & Magnetometer Connector
- J11 - MicroSD
- J12 - RC input / USART6 Connector
- J13 - I2C Display / I2C2 Bus / Safety Switch Connector
Note: Due to supply chain issues, the colors of the connectors on Flight Core are subject to change. If the colors of the connectors on your flight core are different, please disregard.
Flight Core Board Top
| Connector | Summary |
| J1 | VOXL Communications Interface Connector (TELEM2, /dev/ttyS4, UART5) |
| J2 | Programming and Debug Connector |
| J3 | USB Connector |
| J4 | UART ESC, (UART2, /dev/ttyS1, TELEM3 |
| J5 | Telemetry Connector (TELEM1, /dev/ttyS6, UART7) |
| J6 | VOXL-Power Management Input / Expansion |
| J7 | 8-Channel PWM Output Connector (PWM or DShot ESCs) |
| J8 | CAN Bus Connector |
| J9 | PPM RC In |
| J10 | External GPS & Magnetometer Connector (/dev/ttyS0, UART1) |
| J12 | RC Input, Spektrum/SBus/UART Connector |
| J13 | I2C Display (Spare Sensor Connector) / Safety Button Input |
Flight Core Board Bottom
Connector: 6 Position HIROSE DF13, Vertical, DF13-6P-1.25V(50)
Notes: UART lines are 5V inputs (level shifted to 3.3V by the Flight Core)
| Pin # | Signal Name |
| 1 | 5VDC (input or output if supplied at another pin) |
| 2 | UART_4W_RX_5V |
| 3 | UART_4W_TX_5V |
| 4 | UART_4W_RTS_5V |
| 5 | GND |
| 6 | UART_4W_CTS_5V |
Connector: 8 Position, Vertical, BM08B-SRSS-TB(LF)(SN)
Note: used for PX4 debug console, can be used for STM32 FW update
| 1 | VREG_3V3 |
| 2 | UART_2W_DEBUG_TX |
| 3 | UART_2W_DEBUG_RX |
| 4 | SWDIO |
| 5 | SWCLK |
| 6 | GND |
| 7 | !RESET |
| 8 | VPP_STM |
J3 - USB Connector
NOTE: This connector does not provide system power
Connector: 4 Position JST GH, Vertical, BM04B-GHS-TBT
| 1 | VBUS_IN |
| 2 | DATA_M |
| 3 | DATA_P |
| 4 | GND |
Connector: 8 Position HIROSE DF13, Vertical, DF13-8P-1.25V(50)
| 1 | 5VDC (other pins are 3.3V, input or output if supplied at another pin) |
| 2 | UART_4W_RX_3V3 |
| 3 | UART_4W_TX_3V3 |
| 4 | UART_4W_RTS_3V3 |
| 5 | GND |
| 6 | UART_4W_CTS_3V3 |
| 7 | GPIO (MSS Status Output) |
| 8 | GPIO (MSS Status Input) |
Connector: 6 Position JST GH, Vertical, MB06B-GHS-TBT
| 1 | 5VDC (other pins 3.3V, input or output if supplied at another pin) |
| 2 | UART_4W_TX_3V3 |
| 3 | UART_4W_RX_3V3 |
| 4 | UART_4W_CTS_3V3 |
| 5 | UART_4W_RTS_3V3 |
| 6 | GND |
Connector: 6 Position JST GH, Vertical, BM06B-GHS-TBT
| 2 | UART_2W_TX_3V3 |
| 3 | UART_2W_RX_3V3 |
| 4 | EXP_I2C_SCL |
| 5 | EXP_I2C_SDA |
| 6 | GND |
Connector: 10 Position JST GH, Vertical, BM10B-GHS-TBT
Notes: 5V is for Ref Only
| 2 | PWM_CH1 |
| 3 | PWM_CH2 |
| 4 | PWM_CH3 |
| 5 | PWM_CH4 |
| 6 | PWM_CH5 |
| 7 | PWM_CH6 |
| 8 | PWM_CH7 |
| 9 | PWM_CH8 |
| 10 | GND |
| 1 | 5VDC |
| 2 | CANH* |
| 3 | CANL* |
| 4 | GND |
*CAN signals are compliant with ISO 11898-2:2016 and SAE J2284-1 to SAE J2284-5
J9 - PPM RC In
Connector: 3 Position JST GH, Vertical, BM03B-GHS-TBT
Note: This JST connector is reversed when compared to VOXL Flight, pinouts are still the same
| 2 | PPM_IN |
| 3 | GND |
| 2 | EXT_GPS_UART_2W_TX |
| 3 | EXT_GPS_UART_2W_RX |
| 4 | EXT_GPS_I2C_SCL |
| 5 | EXT_GPS_I2C_SDA |
| 6 | GND |
Supported GPS Modules
J11 - MicroSD
MicroSD slot. Information about supported cards is here: https://dev.px4.io/v1.9.0/en/log/logging.html#sd-cards
| 1 | VREG_3V3 (Spektrum Power) |
| 2 | USART6_TX |
| 3 | SPEKTRUM RX (3.3V), SBus RX (3.3V), USART6_RX |
| 4 | GND |
For additional RC configurations, please see Flight Core Radios
Connector: 5 Position, Vertical, BM05B-SRSS-TB(LF)(SN)
| 1 | VREG_3V3 |
| 2 | GND |
| 3 | I2C2_SDA |
| 4 | I2C2_SCL |
| 5 | Safety Switch In (switch should pull high to 3.3V to enable) |
