Flight Core Bootloader
Changelog
| Release | Build Commit | Description | Link |
| 1 | N/A | Alpha Release | N/A |
| 2 | GitLab CI | QGC FW Update Support (bug fix) | downloaded |
Bootloader Binary Location
A prebuilt binary of the latest bootloader can be downloaded from here
How to Build the Bootloader
You can build (and customize) the bootloader as needed. Flight Core is supported in the PX4 Bootloader mainline repository.
git clone https://github.com/PX4/Bootloader
cd Bootloader
make modalai_fc_v1_bl
In Field Bootloader Update Procedure
ModalAI Top Tip! You should know what you’re doing before proceeding as this can brick the device.
- Download the bootloader binary
- Copy the file to the root of a MicroSD card
- Power off the Flight Core
- Insert the MicroSD card into the Flight Core’s MicroSD card slot
- Power on the Flight Core
- Connect Flight Core to QGroundControl using the USB cable
- Note: alternatively you can use the debug serial console
- If using USB, in QGC, go to the MAVLink Console terminal
- Verify the
modalai_fc_v1_bl.binis on the MicroSD card by running the following command:
ls /fs/microsd
The following should (roughly) display:
/fs/microsd:
dataman
log/
- To update the bootloader, run the following command:
bl_update /fs/microsd/modalai_fc_v1_bl.bin
The following should display:
INFO [bl_update] image validated, erasing bootloader...
ERROR [bl_update] erase error at 0x8000100
INFO [bl_update] flashing...
INFO [bl_update] verifying...
INFO [bl_update] bootloader update complete
- Reboot the device and verify it boots up
reboot
Flashing Using SEGGER JLink
You can use JFlash with a .jlink file with command like so:
loadbin modalai_fc_v1_bl.bin,0x08000000
