Build ROS Nodes for VOXL
VOXL ships with the voxl-utils and voxl-nodes package pre-installed alongside ROS Indigo so you can start developing with ROS right away.
You can choose to compile ROS nodes either directly on-target or in the voxl-emulator docker. If you intend to generate an IPK package of our ROS node we suggest building in the emulator docker image and pushing the IPK to VOXL.
How to setup ROS on VOXL can be found here
Setup Notes
The ROS environment running on VOXL is sensitive to the shell environment on the host PC! For best results, SSH from an Ubuntu host machine using XTerm when calling roslaunch or starting roscore.
If you see an error similar to the following, there is likely an issue with the terminal emulation on the host PC. This error is frequently seen when SSH’ing from Windows or MAC, and even the default Ubuntu terminal.
Building on VOXL
1) Prerequisite: you will need to have ros-indigo-build-deps installed to build ROS nodes directly on VOXL. This is not necessary when building in the voxl-emulator docker image.
2) ADB or ssh into VOXL and go to your VOXL’s home directory. This assumes you have followed the previous setup pages in this manual to get ADB and/or ssh working.
james@silverstone:~$ adb shell
/ # bash
/# cd ~/
/home/root#
3) make a new catkin workspace and initialize it with catkin_make
/home/root# mkdir -p catkin_ws/src
/home/root# cd catkin_ws
/home/root/catkin_ws# catkin_make
4) Make a new node source directory in the src folder. Here we use the VOXL time-of-flight node as an example.
/home/root/catkin_ws# cd src
/home/root/catkin_ws/src# git clone https://gitlab.com/voxl-public/tof_cam_ros.git
/home/root/catkin_ws/src# ls
CMakeLists.txt tof_cam_ros
/home/root/catkin_ws/src# cd ../
5) Build!
/home/root/catkin_ws# catkin_make install
6) This installed the newly built ROS node to ~/catkin_ws/install which should be part of your ROS_PACKAGE_PATH if you have voxl-utils installed and it is sourced by the ~/my_ros_env.sh script. Check to confirm
/home/root/catkin_ws# exec bash
/home/root/catkin_ws# env | grep "ROS_PACKAGE_PATH"
ROS_PACKAGE_PATH=/home/root/catkin_ws/install/share:/home/root/catkin_ws/install/stacks:/opt/ros/indigo/share:/opt/ros/indigo/stacks
7) Now you can launch your new ROS node! Note the tof_cam_ros node will fail to start unless you have a TOF sensor installed on VOXL.
/home/root/catkin_ws# cd ../
/home/root# rospack list | grep tof_cam_ros
tof_cam_ros /home/root/catkin_ws/install/share/tof_cam_ros
/home/root# roslaunch tof_cam_ros tof.launch
Building in voxl-emulator Docker Image
You can build a ROS node in the voxl-emulator docker image following the same steps as you did for building on the VOXL itself. However, the process of getting the built package onto the VOXL itself will be different.
The voxl-nodes package and it’s README file provide a great example of how to do this. We recommend copying this project and swapping out the nodes in catkin_ws/src for your own and working from there. It includes instructions on how to build and helper scripts for making a package and installing on VOXL.
https://gitlab.com/voxl-public/voxl-nodes
