Qualcomm Flight RB5 Streamer
rb5-streamer
The rb5-streamer enables RTSP video streaming from the Hi-res camera to a ground station.
Camera Information
| ID | Summary | Usage | Sensor | Pipeline |
| 3 | Front Hi-res | FPV (front) | IMX214 | 4208x3120 (4k), Bayer RGGB 10bit, 30 FPS |
Architecture
In summary, this is what’s happening:
Image Sensor
--> Kernel
--> CameraX/GST
--> rb5-streamer
--> RTSP stream sending frames
--> Video stream viewer e.g. (VLC)
How to Build and Install
If you have a Qualcomm Flight RB5, it comes pre-loaded with the software and there’s no need to re-install unless you want to. If you want to see the source, build and tweak it, the repo is COMING-SOON.
How to Use
Configure to Run on Bootup
The rb5-streamer package installs with a configuration script. You can run the following after you adb onto the target.
- adb onto target
adb shell
sh-4.4#
- Enable the Hi-res camera to start streaming on bootup and start streaming by running
sh-4.4# rb5-streamer-configure factory_enable
- Disable the Hi-res camera from streaming on bootup and stop streaming by running
sh-4.4# rb5-streamer-configure factory_disable
View Service Status
sh-4.4# systemctl status rb5-streamer
● rb5-streamer.service - "rb5-streamer"
Loaded: loaded (/usr/bin/rb5-streamer; indirect; vendor preset: enabled)
Active: active (running) since Mon 2021-07-26 16:28:00 UTC; 15s ago
Jul 26 16:28:00 qrb5165-rb5 systemd[1]: Started "rb5-streamer".
Jul 26 16:28:00 qrb5165-rb5 rb5-streamer[9522]: gbm_create_device(156)
Jul 26 16:28:00 qrb5165-rb5 rb5-streamer[9522]: stream ready at rtsp://127.0.0.1:8554/test
View output stream
The output video stream can be viewed using a number of clients e.g. (VLC, QGroundControl, FFPlay).
Simply point your client to the following url: rtsp://HOST_IP:8554/camera3
where HOST_IP is the IP address of your Qualcomm Flight RB5.
