Qualcomm Flight RB5 SDK Camera Server
rb5-camera-server
The rb5-camera-server allows you to publish data from any of the 6 cameras on the platform.
Camera Information
| ID | Summary | Usage | Sensor | Pipeline |
| 0 | Front Stereo, Left | VOA (front) | ov7251 | 640x480, Bayer B&W 10bit, 30 FPS, hw synced with 1 |
| 1 | Front Stereo, Right | VOA (front) | ov7251, master | 640x480, Bayer B&W 10bit, 30 FPS, hw synced with 0 |
| 2 | Front Tracking | VIO (front) | ov7251 | 640x480, Bayer B&W 10bit, 30 FPS |
| 3 | Front Hi-res | FPV (front) | IMX214 | 4208x3120 (4k), Bayer RGGB 10bit, 30 FPS |
| 4 | Rear Stereo, Left | VOA (rear) | ov7251 | 640x480, Bayer B&W 10bit, 30 FPS, hw synced with 5 |
| 5 | Rear Stereo, Right | VOA (rear) | ov7251, master | 640x480, Bayer B&W 10bit, 30 FPS, hw synced with 4 |
Architecture
In summary, this is what’s happening:
Image Sensor
--> Kernel
--> CameraX/GST
--> rb5-camera-server
--> a named pipe getting frames
--> code reading from named pipe doing stuff
How to Build and Install
If you have a Qualcomm Flight RB5, it comes pre-loaded with the software and there’s no need to re-install unless you want to. If you want to see the source, build and tweak it, the repo is COMING-SOON.
How to Use
Configure to Run on Bootup
Generally, we want to have the computer vision processing start up on bootup. On the Qualcomm Flight RB5, that’s the default setup for camera IDs 0, 1, 2, 4 and 5 (the core computer vision sensors)
The rb5-camera-server package installs with a configuration script. You can run the following after you adb onto the target.
- adb onto target
adb shell
sh-4.4#
- Enable the default computer vision cameras (0, 1, 2, 4, 5) to start on bootup by selecting
1) yes
sh-4.4# rb5-camera-server-configure
Would you like to enable the camera service?
This will start all cameras in a background process
1) yes
2) no
#? 1
View Service Status
We use a ‘templated’ systemd unit file…. so the services show up a little different:
| 0 | Front Stereo, Left | systemctl status rb5-camera-server@0 |
| 1 | Front Stereo, Right | systemctl status rb5-camera-server@1 |
| 2 | Front Tracking | systemctl status rb5-camera-server@2 |
| 3 | Front Hi-res | not started by default, used upon request for FPV stream |
| 4 | Rear Stereo, Left | systemctl status rb5-camera-server@4 |
| 5 | Rear Stereo, Right | systemctl status rb5-camera-server@5 |
For example, camera 0 after successfully starting:
sh-4.4# systemctl status rb5-camera-server@0
● rb5-camera-server@0.service - "rb5-camera-server-0"
Loaded: loaded (/usr/bin/rb5-camera-server; indirect; vendor preset: enabled)
Active: active (running) since Mon 2021-07-26 16:28:00 UTC; 15s ago
Main PID: 9522 (rb5-camera-serv)
Tasks: 4 (limit: 4915)
CGroup: /system.slice/system-rb5\x2dcamera\x2dserver.slice/rb5-camera-server@
└─9522 /usr/bin/rb5-camera-server -c0
Jul 26 16:28:00 qrb5165-rb5 systemd[1]: Started "rb5-camera-server-0".
Jul 26 16:28:00 qrb5165-rb5 rb5-camera-server[9522]: gbm_create_device(156): Inf
Use a Provided Test Client
If you want to test a camera, for example camera ID 5, run the following:
sh-4.4# rb5-camera-client -c 0
camera ID is set to 0
Waiting for server to start: /dev/rb5-camera-pipe-0
View Named Pipes in File System
The interface the rb5-camera-server provides are named pipes where you can read camera frames and meta data from.
sh-4.4# ls -la /dev/rb5-camera*
prw-r--r-- 1 root root 0 Jul 26 15:45 /dev/rb5-camera-pipe-0
prw-r--r-- 1 root root 0 Jul 26 15:45 /dev/rb5-camera-pipe-1
prw-r--r-- 1 root root 0 Jul 26 15:45 /dev/rb5-camera-pipe-2
prw-r--r-- 1 root root 0 Jul 26 15:45 /dev/rb5-camera-pipe-4
prw-r--r-- 1 root root 0 Jul 26 15:45 /dev/rb5-camera-pipe-5
How to Change What Cameras Are Started on Bootup
Currently, the camera’s initialization setup is handled here:
/usr/bin/rb5-camera-server-configure
You’ll find usage like below, where you can enable/disable by ID:
# enables service which starts all cameras
enable_service () {
echo "reloading systemd services"
systemctl daemon-reload
echo "enabling /starting rb5-camera-server systemd service"
# front tracking
systemctl enable rb5-camera-server@2.service
systemctl restart rb5-camera-server@2.service
