Qualcomm Flight RB5 Modem
rb5-modem
rb5-modem is a tool for enabling cellular connection on RB5 Flight via Quectel or Telit 5G modem.
For more info on connecting to a ground station over the 5G network, checkout the following page:
How to Build and Install
If you have a Qualcomm Flight RB5, it comes pre-loaded with the software and there’s no need to re-install unless you want to. If you want to see the source, build and tweak it, the repo is COMING-SOON.
How to Use
Configure to Run on Bootup
The rb5-modem package installs with a configuration script. You can run the following after you adb onto the target.
- adb onto target
adb shell
sh-4.4#
rb5-modem-configure
You will be prompted to select your modem hardware and APN (Access Point Name) for your chosen SIM card.
This will enable the rb5-modem service in the background and it will be started at boot.
The configuration file located at /etc/modalai/rb5-modem.conf can be modified directly to change settings as well.
- Enable rb5-modemto connect to network on bootup and start
sh-4.4# rb5-modem-configure factory_enable
- Disable rb5-modemfrom connecting to network on bootup and kill network by running
sh-4.4# rb5-modem-configure factory_disable
View Service Status
sh-4.4# systemctl status rb5-modem
● rb5-modem.service - "rb5-modem"
   Loaded: loaded (/usr/bin/rb5-modem; indirect; vendor preset: enabled)
   Active: active (running) since Mon 2021-07-26 16:28:00 UTC; 15s ago
Jul 26 16:28:00 qrb5165-rb5 systemd[1]: Started "rb5-modem".
Jul 26 16:28:00 qrb5165-rb5 rb5-streamer[9522]: Initializing network connection...
Connecting to QGroundControl
Checkout this page for info on Connecting to QGC over 5G using a VPN
