All single ended signals on B2B connectors J3, J5, J6, J7, and J8 are 1.8V CMOS unless explicitly noted. All single ended signals on cable-to-board connectors J10, J11, J12,J18, & J19 are 3.3V CMOS unless explicitly noted.
Connector
Description
MPN (Board Side)
Mating MPN (Board/Cable Side)
Type
Signal Feature Summary
J1
SOM Interface
SEAF8-50-05.0-L-10-2-K
SOM
High Density 500-pin B2B
All power and signal interfaces to the RB5 SOM
J2
Fan
SM02B-SRSS-TB(LF)(SN)
SHR-02V-S
Cable Header, 2-pin R/A
5V DC for FAN + PWM Controlled FAN-Return (GND)
J3
Legacy B2B
QSH-030-01-L-D-K-TR
QTH-030-01-L-D-A-K-TR
B2B Receptacle, 60-pin
5V/3.8V/3.3V/1.8V power for plug-in boards, JTAG and Debug Signals, QUP expansion, GPIOs, USB3.1 Gen 2 (USB1)
J4
Prime Power In
22057045
0050375043
Cable Connector, 4-pin R/A
+5V main DC power in + GND, I2C@5V for power monitors
J5
High Speed B2B
ADF6-30-03.5-L-4-2-A-TR
ADM6-30-01.5-L-4-2-A-TR
B2B Socket, 120-pin
More 3.8V/3.3V/1.8V power for plug-in boards, 5V power in for “SOM Mode”, QUP expansion, GPIOS (including I2S), SDCC (SD Card V3.0), UFS1 (secondary UFS Flash), 2L PCIe Gen 3, AMUX and SPMI PMIC signals
J6
Camera Group 0
DF40C-60DP-0.4V(51)
DF40C-60DS-0.4V
B2B Plug, 60-pin
Qty-2 4L MIPI CSI ports, CCI and camera control signals, 8 power rails (from 1.05V up to 5V) for cameras and other sensors, dedicated SPI (QUP) port
J7
Camera Group 1
DF40C-60DP-0.4V(51)
DF40C-60DS-0.4V
B2B Plug, 60-pin
J8
Camera Group 2
DF40C-60DP-0.4V(51)
DF40C-60DS-0.4V
B2B Plug, 60-pin
J9
USB-C
UJ31-CH-3-SMT-TR
USB Type-C
Cable Receptacle, 24-pin R/A
USB-C with re-driver and display port alternate mode (USB0)
J10
SPI Expansion
SM08B-GHS-TB(LF)(SN)
GHR-08V-S
Cable Header, 8-pin R/A
SPI@3.3V with 2 CS_N pins, 32kHz CLK_OUT@3.3V
J11
Reserved for Future
SM04B-GHS-TB(LF)(SN)
GHR-04V-S
Cable Header, 4-pin R/A
Spare I2C not pinned on SOM, reserved for future use. Do not use.
J12
R/C UART
BM04B-GHL-TBT(LF)(SN)(N)
GHR-04V-S
Yellow Cable Header, 4-pin Vertical
R/C UART@3.3V, 3.3V_RC switchable voltage
J18
ESC
GHR-04V-S
ESC UART@3.3V, 3.3V reference voltage
J19
GNSS/MAG
SM06B-GHS-TB(LF)(SN)
GHR-06V-S
Cable Header, 6-pin R/A
GNSS UART@3.3V, Magnetometer I2C@3.3V, 5V
Connectors
J2 Fan
J2 Fan Pin-out
Pin#
Signal
Notes/Usage
VDC_5V_LOCAL
5V protected power output *
FAN RETURN (GND)
Return limited to ~400mA
J3 Legacy Board to Board Connector
The Legacy Board to Board connector is designed to host VOXL Add-ons such as the LTE Add-on v2 and the Microhard Add-on.
Connector
MPN
Board Connector
QSH-030-01-L-D-K-TR
Mating Connector
J3 Pin-out
Odd Pin #
Signal/Voltage
Even Pin #
Signal/Voltage
DGND
VDC_5V_LOCAL
GPIO_23_UART7_RXD
VDC_5V_LOCAL
GPIO_22_UART7_TXD
VDC_5V_LOCAL
GPIO_52_SPI17_MISO
8
USB1_HS_ID_LEGACY (Normally N.C.)
9
GPIO_53_SPI17_MOSI
10
DGND
11
DGND
12
USB1_HS_DM
13
GPIO_126_I2C9_SCL
14
USB1_HS_DP
15
GPIO_125_I2C9_SDA
16
VDC_5V_LOCAL_USB1
17
GPIO_55_SPI17_CS
18
DGND
19
GPIO_54_SPI17_SCLK
20
USB1_SS_TX_M
21
DGND
22
USB1_SS_TX_P
23
GPIO_130_I2C10_SCL
24
GPIO_20
25
GPIO_129_I2C10_SDA
26
GPIO_21
27
GPIO_35_DBG_UART12_RX
28
GPIO_32_QUP12_L0
29
GPIO_34_DBG_UART12_TX
30
GPIO_33_QUP12_L1
31
DGND
32
USB1_SS_RX_M
33
JTAG_SRST_N
34
USB1_SS_RX_P
35
JTAG_TCK
36
DGND
37
JTAG_TDI
38
GPIO_131_USB_HUB_RESET
39
JTAG_TDO
40
GPIO_124
41
JTAG_TMS
42
GPIO_145
43
JTAG_TRST_N
44
DGND
45
JTAG_PS_HOLD
46
GPIO_90_FAST_BOOT_3
47
VREG_S4A_1P8
48
GPIO_76_FAST_BOOT_2
49
PM_RESIN_N
50
GPIO_47_SPI14_CS2_FAST_BOOT_1
51
SDM_RESOUT_N
52
GPIO_27_FAST_BOOT_0
53
VREG_3P3V_LOCAL
54
GPIO_128_WDOG_DIS
55
KPD_PWR_N
56
SDM_FORCE_USB_BOOT
57
VPH_PWR
58
DGND
59
DGND
60
CLK_PMK_PMIC
J4 Prime Power-in
J4 Prime Power-in Pin-out
Pin#
Signal
Notes/Usage
VDCIN_5V
DC from Power Module, “unprotected”
GND
Power Module Return
I2C_CLK
SSC_QUP_1, 5V signal levels, Pullups on Power Module
I2C_SDA
J5 High-speed Board to Board Connector
Connector
MPN
Board Connector
Mating Connector
J5 Pin-out
Pin
Signal/Voltage
Pin
Signal/Voltage
Pin
Signal/Voltage
Pin
Signal/Voltage
A1
VDCIN_5V
B1
VDCIN_5V
C1
VDCIN_5V
D1
VDCIN_5V
A2
VDCIN_5V
B2
VDCIN_5V
C2
VDCIN_5V
D2
VDCIN_5V
A3
GND
B3
GND
C3
GND
D3
GND
A4
GND
B4
GND
C4
GND
D4
GND
A5
VREG_3P3V_LOCAL
B5
GND
C5
GPIO_119_SPI3_MISO
D5
GPIO_36_UART13_CTS
A6
VREG_3P3V_LOCAL
B6
GND
C6
GPIO_120_SPI3_MOSI
D6
GPIO_37_UART13_RTS
A7
GND
B7
GPIO_16_QUP6_L0
C7
GPIO_121_SPI3_SCLK
D7
GPIO_38_UART13_TXD
A8
GPIO_115_I2C2_SDA
B8
GPIO_17_QUP6_L1
C8
GPIO_122_SPI3_CS
D8
GPIO_39_UART13_RXD
A9
GPIO_116_I2C2_SCL
B9
GPIO_18_QUP6_L2
C9
GPIO_24_I2C8_SDA
D9
GPIO_8_I2C4_SDA
A10
GPIO_117_QUP2_L2
B10
GPIO_19_QUP6_L3
C10
GPIO_25_I2C8_SCL
D10
GPIO_9_I2C4_SCL
A11
GPIO_118_QUP2_L3
B11
GPIO_155
C11
GND
D11
PM8250_AMUX1
A12
SD_UFS_CARD_DET_N
B12
GPIO_154
C12
GPIO_145 (intentional duplicate to Legacy B2B pin 42)
D12
GND
A13
GND
B13
GPIO_153
C13
GPIO_144
D13
PCIE2_REFCLK_M
A14
SDC2_CLK
B14
GPIO_152
C14
GPIO_143
D14
PCIE2_REFCLK_P
A15
GND
B15
GND
C15
GPIO_142
D15
GND
A16
VREG_L9C_2P96
B16
GPIO_0_QUP19_L0
C16
GPIO_137
D16
PCIE2_RX0_M
A17
SDC2_CMD
B17
GPIO_1_QUP19_L1
C17
GND
D17
PCIE2_RX0_P
A18
SDC2_DATA_0
B18
GPIO_2_QUP19_L2
C18
GPIO_88
D18
GND
A19
SDC2_DATA_1
B19
GPIO_3_QUP19_L3
C19
GPIO_89
D19
PCIE2_RX1_M
A20
SDC2_DATA_2
B20
GPIO_56_I2C18_SDA
C20
GPIO_87_PCIE2_WAKE_N
D20
PCIE2_RX1_P
A21
SDC2_DATA_3
B21
GPIO_57_I2C18_SCL
C21
GPIO_86
D21
GND
A22
GND
B22
GND
C22
GPIO_85
D22
PCIE2_TX0_M
A23
UFS1_REFCLK
B23
GPIO_60_QUP11_L0
C23
GND
D23
PCIE2_TX0_P
A24
GND
B24
GPIO_61_QUP11_L1
C24
PMIC_8150L_AMUX1
D24
GND
A25
UFS1_TX0_M
B25
GPIO_62_QUP11_L2
C25
GND
D25
PCIE2_TX1_M
A26
UFS1_TX0_P
B26
GPIO_63_QUP11_L3
C26
GND
D26
PCIE2_TX1_P
A27
GND
B27
GND
C27
GND
D27
GND
A28
UFS1_RX0_M
B28
SPMI_CLK
C28
VPH_PWR_3P8V
D28
GND
A29
UFS1_RX0_P
B29
SPMI_DATA
C29
VPH_PWR_3P8V
D29
VREG_S4A_1P8
A30
GND
B30
GND
C30
VPH_PWR_3P8V
D30
VREG_S4A_1P8
J6, J7, and J8 Camera Group [0:2] High-speed Board to Board Connector
Connector
MPN
Board Connector
DF40C-60DP-0.4V(51)
Mating Connector
DF40C-60DS-0.4V
J6, J7, and J8 Pin-out (generic group pinout, please work with ModalAI for any mating designs to gauranteee proper operation)
Pin#
Signal
GND
GND
Lower CCI_I2C_SDA
DVDD 1.2V
Lower CCI_I2C_SCL
DOVDD 1.8V
GND
8
DVDD 1.05V
9
Lower CSI_CLK_P
10
Lower RST_N
11
Lower CSI_CLK_M
12
Lower MCLK
13
Lower CSI_DAT0_P
14
GND
15
Lower CSI_DAT0_M
16
Lower CCI Timer
17
GND
18
Upper CCI Timer
19
Lower CSI_DATA1_P
20
Upper MCLK
21
Lower CSI_DATA1_M
22
AVDD 2.8V
23
Lower CSI_DATA2_P
24
GND
25
Lower CSI_DATA2_M
26
Upper RST_N, Shared
27
GND
28
Upper CCI_I2C_SDA
29
Lower CSI_DATA3_P
30
Upper CCI_I2C_SCL
31
Lower CSI_DATA3_M
32
Spare MCLK/GPIO
33
GND
34
Group SPI MISO
35
Upper CSI_CLK_P
36
Group SPI MOSI
37
Upper CSI_CLK_M
38
Group SPI SCLK
39
Upper CSI_DATA0_P
40
Group SPI CS_N
41
Upper CSI_DATA0_M
42
VREG_S4A_1P8
43
GND
44
GND
45
Upper CSI_DATA1_P
46
VPH_PWR 3.8V
47
Upper CSI_DATA1_M
48
VPH_PWR 3.8V
49
Upper CSI_DATA2_P
50
GND
51
Upper CSI_DATA2_M
52
3.3V
53
GND
54
GND
55
Upper CSI_DATA3_P
56
5V
57
Upper CSI_DATA3_M
58
5V
59
GND
60
GND
J10 SPI Expansion
J10 SPI Expansion Pin-out
Pin#
Signal
Notes/Usage
VREG_3P3V_LOCAL
3.3V Power Output *
MISO (Input)
APPS_QUP_14, 3.3V signal levels
MOSI (Output)
SCLK (Output)
CS0_N (Output)
CS1_N/GPIO_46 (Output)
Second SPI CS_N or GPIO
32K_CLK_OUT (Output)
32kHz PMIC Sleep CLK, 3.3V signal levels
8
GND
GND
J12 R/C UART (Spektrum/DSMX)
J12 R/C UART (Spektrum/DSMX) Pin-out
Pin#
Signal
Notes/Usage
VREG_3P3V_RCL
3.3V Switchable Power Output *
RC_UART_TX (Output)
APPS_QUP_13, 3.3V signal levels
RC_UART_RX (Input)
GND
GND
J18 ESC UART
J18 ESC UART
Pin#
Signal
Notes/Usage
VREG_3P3V_LOCAL
3.3V Power Output *
ESC_UART_TX (Output)
SSC_QUP_2, 3.3V signal levels.
ESC_UART_RX (Input)
GND
GND
J19 GNSS/MAG
J19 GNSS/MAG
Pin#
Signal
Notes/Usage
VDC_5V_LOCAL
5V protected Power Output *
GNSS UART TX (output)
APPS_QUP_18, 3.3V signal levels
GNSS UART RX (input)
MAG I2C SCL
SSC_QUP_0, 3.3V signal levels, 2.2K Pullup to VREG_3P3V_LOCAL
MAG I2C SDA
GND
GND
Power Input/Output Important Note:
All power outputs on cable connectors are rated for 1A, however, the system cannot provide 1A simultaneously on all connectors. Contact ModalAI for design assistance.
The difference between VDCIN_5V and VDC_5V_LOCAL is very important. The power module provides VDCIN_5V (raw voltage input) to the platform. On-board is an eFuse that protects the system from accidental wrong-voltage application, droops/brown-outs, or down-stream shorts or overloads. The output of the eFuse is VDC_5V_LOCAL (i.e.: protected output).
